Cab Water Leak
Old Dec 10, 2012 | 04:47 PM
TexasGuy001's Avatar
TexasGuy001
Just so you know, there isn't much of a seal on the 3rd brake light. Its just got some thin foam rubber on it.
Old Dec 10, 2012 | 04:53 PM
Evan_P's Avatar
Evan_P
Originally Posted by Puddy
have you happen to check behind the fan motor to see if the air system has condinsation in it? maybe the vac actuator for the defrost is letting in water that is dripping into the vents.
Bingo! Pulled the blower motor out and the chamber where the blend door is is wet. The foam around the door is wet. Then I went in the cab and checked this vent. It has standing water in it.
This is the far right side of the firewall, next to the passenger side kick panel.
Vacuum actuator switches just fine though... It is fairly difficult to change the temperature setting.
Old Dec 10, 2012 | 05:06 PM
fdude64's Avatar
fdude64
good work I been following but didn't have any ideas but I have had some occasional wetness on my floor too
Old Dec 10, 2012 | 05:46 PM
Puddy's Avatar
Puddy
Yay I got something right!
Old Dec 10, 2012 | 05:52 PM
Evan_P's Avatar
Evan_P
Should I suspect the actuator is bad, even though it changes positions?
Old Dec 10, 2012 | 05:58 PM
Puddy's Avatar
Puddy
I'm thinking the foam to the firewall is bad, if the actuator still moves with vacuum then all is good, I would just leave the garden hose over that area and see what happens
Old Dec 10, 2012 | 06:13 PM
Evan_P's Avatar
Evan_P
Oh... I sure hope not. That entails taking the dash out completely doesn't it?
Old Dec 10, 2012 | 07:10 PM
Puddy's Avatar
Puddy
... I believe so. Or I'm sure you could just loosen it up enough to shimmy in a new one if it is what it is
Old Dec 10, 2012 | 10:29 PM
Evan_P's Avatar
Evan_P
Well I am going to check the drain for the A/C as well as the heater core. If those look good I guess the firewall insulation is the likely culprit. Think they run in the neighborhood of $200...
Old Dec 11, 2012 | 12:29 AM
Puddy's Avatar
Puddy
What if you just did a clean job with some silicone?? Or at least tear into one at a u-pull for one and use it as a template to cut something thicker?
Old Dec 11, 2012 | 02:13 AM
Andrew James's Avatar
Andrew James
Pulling the dash is real simple, the first time I did mine was at three AM with only my cellphone as light and I did it no problem. You can do it if you have too.
Old Dec 11, 2012 | 04:04 PM
Evan_P's Avatar
Evan_P
Well I went out to check the heater core and the evaporator drain tube. Can't seem to find the drain tube. Checked the heater core. Looks like it might have been replaced at some point in time. Nice looking aluminum heater core. No leaks at all. Anyone know where the evaporator drain tube is? Do these trucks have one?
Old Dec 11, 2012 | 06:10 PM
  #28
Puddy's Avatar
Puddy
Old Dec 11, 2012 | 06:17 PM
  #29
Evan_P's Avatar
Evan_P
Ummm... I don't see it on there...
Old Dec 11, 2012 | 08:29 PM
  #30
OldGrayFord's Avatar
OldGrayFord
I had a similar problem and found it to be a combo of cracked seam sealer between the cowl and firewall and drip rails. the cracked seamsealer was impossible to find without removing the cowl. It was down almost behaind the fender
