Roller motor build??
Old Dec 8, 2012 | 03:57 AM
Spicoli27's Avatar
Spicoli27
Okay so I am looking to build a ford total roller motor but I'm not sure what motor to use I want it to be able to rev up in higher RPMS but still have tourqe and still be able to afford a block I am thinking about a 390 351clevland or a 352 any suggestions on any better motors for this project?
Old Dec 8, 2012 | 12:06 PM
HIO Silver's Avatar
HIO Silver
Welcome to FTE.... first, please use some punctuation (periods!) for us FTE'ers. Thanks.
Second, the FE engine series aren't known to be revvers. Unless you've got lots of coin for balancing, knife edging, and other hi-perf mods, FE engines are typically done around 5,000 RPM.
Your best bet is a 4V 351C or the Windsors (302/351 and its strokers).. preferably the latter for the xtra cubes to move these heavy rigs off the line.
Lastly, WHY do you want high RPMs? What is the intended use of the truck? Bragging rights? Or is this a street/strip use?
Old Dec 8, 2012 | 12:20 PM
Spicoli27's Avatar
Spicoli27
The truck is a 1978 ford that I have built with 4:56 gears with a Dana 60 front and rear.
The truck has 40 inch boggers and i am tired of the 400m in it and want something with more power and want to be able to hammer down when I get into deep mud.
I have a 429 sitting in my shop and I have contemplated just using that.
Old Dec 8, 2012 | 12:26 PM
HIO Silver's Avatar
HIO Silver
I was gonna say go with a 460 but was assuming this was 2WD. Thanks for the info.... that gives us background on what yer doing and what ya wanna do.
I'd use the 429. IIRC, it'll bolt up to the tranny too. Balancing and cam/valve train selection will get the higher RPMs. Make a call to Comp Cams or Crane and let'em know what you wanna do.
Also, check out links for 429/460 builds in this post (scroll down): https://www.ford-trucks.com/forums/1...l#post12560261
Oh, thanks for the sentence structure too... only had to read it one time without parsing it in my head.
Joe Hawdon
Oct 6, 2015 03:33 PM
Redneck-Cowboy
Jan 17, 2012 10:05 PM
FBerger
Dec 27, 2005 08:21 AM
mustange70
Offroad & 4x4
Oct 2, 2004 11:27 PM
1 Big Mike
Oct 28, 2002 08:05 PM
