ScanGauge II denier
Old 12-06-2012 | 10:44 PM
DieselVol's Avatar
DieselVol
Originally Posted by amdriven2liv
Where did he shoot? (let me know, I will get out my temp gun and see how it reads and compares for me)
Also, my Torque APP reads right with the SGII. That is the only comparison I have done.
What were the differences?
The SGII can only read what the PCM is reading.
And the oil temp sensor is right after the oil cooler. If he is taking the readings from some place else, like the oil pan, wouldn't he see different temps? Since the ump takes from the pan directly to the oil cooler, the pan will read higher
And as far as being in a "coolant pool", where better than the oil cooler?
So, the only place to shoot for comparison will be at the area of the sensor it's self.
I recall he mentioned the oil pan and the end of the dip stick as he pulled it out (I'd be concerned about rapid head loss there due to a lack of mass), but I don't recall anywhere else at the moment.
What does the Torque app read from?
The differences were usually about 10-15 degrees.
The oil in the cooler is always hotter than the coolant after the truck is fully warmed up, AND the idea is to exchange the heat from the hotter oil into the cooler coolant, then the temp is the oil cooler is not a good place to measure the temp of the coolant. I think.
Old 12-07-2012 | 07:48 AM
bismic's Avatar
bismic
The only oil and coolant temperature sensors a stock engine has are the OEM ones - the ones that the PCM reads. Unless you add on a thermocouple, EVERY gauge system you use will read from the same sensors.
Old 12-07-2012 | 02:46 PM
davbeisner's Avatar
davbeisner
Benny, you said cold soak temps should be 1-2* delta tops... I've got two 6.0 trucks now, and both are showing 3-4.5* deltas after 10-12 hour cold soak with ambient temps in low teens... Do I need to replace those, or just adjust my deltas while hot by a couple degrees? EOT is warmer in both after cold soak...
Hijack over... Sorry!
Old 12-07-2012 | 08:55 PM
BLADE35's Avatar
BLADE35
Thats getting to far apart
And it might not be Off Lineal it may be Multiple
I would just replace the Sensor thats Off sounds like EOT sensor
Old 12-07-2012 | 09:26 PM
davbeisner's Avatar
davbeisner
Ok, thx... I'll try swapping EOT and ECT sensors first and see if they are off opposite. If so, I'll know I have a bad one. If EOT is still showing high, what's the next step? (Sorry for the continued hijack!)
Old 12-07-2012 | 09:31 PM
BLADE35's Avatar
BLADE35
Wire Chaffe at that point
Old 12-07-2012 | 09:32 PM
DieselVol's Avatar
DieselVol
Since its my thread, I'll make it legit and join the hijack. How hard is it to swap sensors? Is it just an unplug, an unscrew, or are you pulling a probe all of the way out that will have oil or coolant dripping off the end? Also, are they expensive to replace? Can you get them at a parts store or straight from Ford? Let the hijack roll on!
Old 12-07-2012 | 09:36 PM
davbeisner's Avatar
davbeisner
Haha, those would've been my next questions, too... I guess for me the biggest surprise was getting two trucks with exactly the same cold soak temps and exactly the same spreads!
Old 12-07-2012 | 09:41 PM
BLADE35's Avatar
BLADE35
you will swap sensors/probes out
Back the oil filter cap off and so the oil filter housing will drain then pull Oil Temp sensor
Then pull the Coolant temp sensor and have the Oil sensor ready to go in Fast as this coolant may leak alittle
Old 12-07-2012 | 09:46 PM
DieselVol's Avatar
DieselVol
Found the oil temp sensor online for $32. Does the pig tail fail? Can that be replaced?
Old 12-07-2012 | 10:02 PM
BLADE35's Avatar
BLADE35
I think if only off a Few degrees its just a sensor not wiring issue but I could be wrong here as well
I say that^^ because these temp sensors are a Thermistor type sensor
Old 12-07-2012 | 10:19 PM
DieselVol's Avatar
DieselVol
Nice diagram, thanks Benny. I'll test mine out tomorrow morning with a long interstate run. If my EOT-ECT is still out to 20+, it's time to start looking at the sensors.
  #28
Old 12-07-2012 | 11:01 PM
BLADE35's Avatar
BLADE35
If ECT and EOT is same temp right at startup within 10-15 seconds odds are sensors are Good and you need a New Oil Cooler
Guess I should read your other thread to get the Fill Picture here
  #29
Old 12-08-2012 | 04:19 AM
DieselVol's Avatar
DieselVol
Hopefully you have by now and his is unnecessary, but I just replaced it since it was getting studs anyway. The other reason I replaced it was that the delta was consistently running 12-14 at hwy speeds and thus I figured it was about time anyway. Those temps improved very little despite the new cooler, often getting to 11-13. It got worse last week when the coolant level dropped due to the degas bottle hole. I'm about to leave to find out what it will do now.
  #30
Old 12-08-2012 | 07:54 AM
mustang_309's Avatar
mustang_309
One thing to also consider when looking at temp gun readings vs temp probe readings is the probe is actually in the fluid where the temp gun is reading the material between the actual liquid and the gun itself and some energy has already been given up through heat tranfer. If this has already been pointed out in this thread i apologize and will learn to read better
Quick Reply: ScanGauge II denier
