Howards Cams Retro-Fit Hydraulic Roller Camshaft
All Howards™ cams are ground at Howards Cams™, not reboxed like some cam companies. All Howards™ cams use the highest-grade race quality cores available. Howards™ cams are manufactured on dedicated high precision cam grinding machines. Most Howards™ cams are packaged and shipped in our unique, hard, high impact plastic reusable cases. This ensures that the high quality camshaft that went into the case comes out in the same condition, when delivered, as when it was packed.
♦ 100% ground at Howards Cams™ (no re-box)
♦ High grade race quality cores
♦ Hard protective packaging Note: Stock (O.E.) valve springs cannot be used. Note: Requires use of retro-fit tie bar hydraulic roller lifters. Note: Must use 1-3-7-2-6-5-4-8 ignition firing order.
See...my version says 209hp@3500rpm and 332tq@3000rpm which compares well with my Chiltons manual.. 210hp@3600rpm and 325tq@2800rpm.
I get similar result with DD03.
Sorry for the Hijack FYG35.
Roller rockers reduce friction and you gain a little performance on the top end. They are not needed. However Comp is recommending that cam, 35-320-8 be used with 1.7:1 ratio rockers which give more valve lift over the stock 1.6.
If you go with it, can afford the extra expense of rockers, you might as well get roller rockers, $170. Hmmmm, we haven't mentioned a good double roller timing set either, $40. The timing set is more important than the rockers. Figure-in gaskets as well. I wonder if you will be able to use the stock push rods? The heads should come with that info. or it should be in the specs online.
It can get expensive and a budget often helps with part decisions.
Comp Cams says the 35-320-8 was designed for use with 1.7 rockers, that does not mean it requires 1.7 rockers, it'll work just fine with a 1.6 ratio and those will keep total valve lift within the capabilities of the stock valvetrain. If you put 1.7s on it you'll also need new springs, locks, and retainers.
okay ive got the gaskets covered.... But do i need anything other than the parts ive ordered because i planned on reusing stock hard ware.. as of now the explorer 5.0 is able to be dropped in with its stock stuff right now.. but im gonna swap the gt40x heads, headers and whichever cam you guys help me decide on and drop it in the truck and go... but as of the rods, lifters and all that stuff will i need anything hardware wise or is it as simple as just doing a parts swap? if you havent caught on this is my first rebuild... ill have some professional help tho..
Well I got the summit brand shorty headers so as far as the ports fitting i dont know but I still haven't even ordered the heads or cam until y'all can help me decide on a setup that will work
Those heads are not complete, look at them again, and add up the parts needed. Then you might consider a set of used GT40X heads and a mild cam to avoid having to get larger injectors and tune...........................Like Comps 35-308-8
There's nothing wrong with setting a budget and buying the power you can afford. It gets expensive real fast, the expense go up way faster than the actual power gains!
This is for Conanski and you. I think many have gotten away with maxing-out the injectors because it is only for a short time when hitting the higher RPMs and I believe the injector calcs to be conservative. I have seen many builds that show around 300hp that survive and run fine. Ya they survive but are not likely to be getting the most out of them without a tune. Calibrated MAF meters to injector are band-aid, but I have seen them work OK.
Corral.net is a good place to find used heads, better yet, a wrecking yard pick-n-pull.
Well what if I said F the heads since its already got gt40p's and just got a cam.. I just want to see a noticeable difference over stock.. Because I was used to driving a regular bone stock f150 5.0 with 200,000k miles.. So with just headers and a cam would I notice anything? And would people know that what's under the hood isn't stock?
Yup, the Comp cam 35-308-8, headers, and a decent exhaust with the right chamber style muffler would make it sound pretty damn good, you'll get more power over a stock engine, and you will also notice an improvement with the fresh engine.
Put the "search" function to work to look for what mufflers folks are running and what they sound like. Seems to me the exhaust may need some work with all the mile so it. Well unless that has already been fixed. I like Flowmaster, but they are pricey and there are alterantive that sound as good.
Then you might consider a set of used GT40X heads and a mild cam to avoid having to get larger injectors and tune...........................Like Comps 35-308-8.
