Coil spring mounts
Old Dec 6, 2012 | 06:20 AM
4x4falcon's Avatar
4x4falcon
Coil spring mounts
A question for whoever.
1986 F100 4x4 Right hand drive.
I've pulled the front suspension apart in preparation for the installation of a lift kit.
Did not take much notice when disassembling the lower coil spring mounts and it was only when I was cleaning the rust and crud off them that I noticed one was about 8mm (5/6in) taller than the other.
So I checked in my parts list (original Ford Australia) and find that there is a different part for right and left side but which is which.
My guess is that the taller one goes on the right side to compensate for the weight of the driver (right hand drive vehicle).
However it could just as easily go on the left side to compensate for the weight of the mid fuel tank.
Or should they really be the same height.
Any ideas?
Cheers
Ross
Old Dec 6, 2012 | 02:26 PM
Franklin2's Avatar
Franklin2
I tried to do a search on the subject, and they only thing that came up was possibly the taller one goes on the pass side. What I would do is try to find a reference point. I suppose the spindle where the wheel bearings ride would be a good one if you can somehow use it. Measure from there to the top of the axle where the spring seat sits, and see if one of the axle housings is thicker than the other from the spindle reference to the spring seat.
Old Dec 6, 2012 | 07:29 PM
4x4falcon's Avatar
4x4falcon
By pass side I gather you mean the right hand side as your referring to a USA delivered vehicle. This is what I had seen but I can not find it again.
Had not thought of that. Will have to check.
Cheers
Ross
Old Dec 10, 2012 | 02:10 AM
4x4falcon's Avatar
4x4falcon
Solved
The higher one goes on the right hand side.
I don't know why.
A mate of mine who is back in town owns a 1986 F100 4x4 as well so just went and had a look at his.
Cheers
Ross
ford79man91
Jul 16, 2007 11:29 PM
97ranger xlt
Jan 22, 2007 10:12 AM
towtruck
Nov 4, 2004 08:16 AM
WC76TX
Jul 3, 2002 10:56 AM
kassonb
Offroad & 4x4
Jul 22, 2001 12:25 PM
