Heater problems for my '65
Old Dec 5, 2012 | 07:29 PM
Koamileli's Avatar
Koamileli
New guy here...and new to the Ford world in general....just picked up my lovely '65 F100 long bed and she's got a heater issue. The motor never runs hot, and the heater blower runs perfect on both speeds, along with all the flapper doors operating as they should. Problem is, even after replacing the thermostat, warm air never comes out. It's always cold. I have the deluxe heater, and from what I've read, the right hand **** on the under dash panel is the temp control for the deluxe model. Could the heater core be to blame? I just don't feel like paying $150 just to have the dealer diagnose it and then another god knows how much for labor charges. I thank everyone in advance of their knowledge and advice. I love my new truck and I'm looking forward to spending a lot of time with her (in a warm cab preferably)
Old Dec 5, 2012 | 08:06 PM
664x4drvr's Avatar
664x4drvr
I am shooting from the hip here, I have NOT taken my heater apart. BUT I have fixed many things on my truck, That I did not know how to do. THANKS TO GUYS HERE!!!!!!!!!! Take pictures , notes and fix it yourself, It's part of the pride of ownership. although I did replace one on my 85 250 , it wasn't that bad.
Old Dec 5, 2012 | 09:47 PM
bertha66's Avatar
bertha66
Welcome to the site; check to see if your heater control valve is opening. It will be on the fender well on the passenger side, in line of the heater hose. If it is open and closing ok, pull the hoses loose and blow though them to see if you have a pugged core. What temp stat did you install?
Old Dec 5, 2012 | 10:04 PM
smokenchoken's Avatar
smokenchoken
i agree wholeheartedly with post above sounds like an issue with the valve being rusted shut or the core is plugged you should (if its like my 66) be able to pull your heater **** out about 2"-3" and it is that wire that operates the ball valve... another thing which i have seen is if it has been sitting for a while a mouse or rat will build a nest in there and all you have to do is disassemble and clean it is pretty straightforward to remove heater in these trucks 3 little 7/16" nuts and remove the heater hose's and as you remove it there are a few wires which are easy to remove pretty easy..... also a dumb question but i see it alot are the heater hoses even hooked up a quite often if the heater core was leaking the P.O. might have just looped them back into themselves and no fluid is running through the core at all good luck
Old Dec 6, 2012 | 07:28 AM
Koamileli's Avatar
Koamileli
Not sure of the temp rating on the thermostat, it's whatever the autozone people ordered up for me...though I have noticed that the engine is running a bit cooler since the install. I took it on a 3 hour drive yesterday and realized that towards the end of the trip it started to blow a little less cold air. I'll check my hoses today for clogs. If everything else checks good, is it still possible for the core to be plugged up? And if so is it possible to clean it out? Or do I have to install a new one...
Old Dec 6, 2012 | 09:31 AM
bertha66's Avatar
bertha66
Did you install the stat in the right way, it has happened. Also, just because the stat is new, does not mean that it is working, it may be stuck open. Stat goes in with the spring end into the intake.
Old Dec 6, 2012 | 09:35 AM
Boss9F100's Avatar
Boss9F100
There is really no diagnosing to do. Just grab heater hoses with engine warm. is one hot or both? If both hot the water is circulating just fine. Check both sides of valve too.
If the heater core does need to be changed just do it yourself. We can guide you thru that to save you the $$ and you will be happy you did it yourself.
It really could not be a simpler one to learn on. Don't say you CANNOT because you can.
Old Dec 6, 2012 | 09:40 AM
Boss9F100's Avatar
Boss9F100
Heater core's are cheap and you can do it on your own.
A couple pics of assy. Done forget the retaining clip that holds core in place.
<center>
<img src="http://img.photobucket.com/albums/v513/CalypsoCoralBoss302/1966%20F100%20427/Interior/8cf87f2b.jpg"><br/><br/>
<img src="http://img.photobucket.com/albums/v513/CalypsoCoralBoss302/1966%20F100%20427/Interior/f697b5fd.jpg"><br/><br/>
<img src="http://img.photobucket.com/albums/v513/CalypsoCoralBoss302/1966%20F100%20427/Interior/8edf10dc.jpg">
<br/><br/>
</center>
Old Dec 6, 2012 | 10:09 AM
Koamileli's Avatar
Koamileli
I did install the stat spring side into the intake, and the temp needle moves, so that part seems to be working fine...I'm heading out shortly to look everything over again and see what I can find. Thank you for the photos
Old Dec 6, 2012 | 11:12 AM
Koamileli's Avatar
Koamileli
So both heater hoses are cold....I even loosened them at the firewall to check the temp of the coolant and yes, it's cold too. I'm guessing the hose from the top of the intake that also has the inline ball valve is the supply hose and the one going to the water pump is the return? I thought maybe the temp rating for the thermostat was too low at first, but am i wrong for thinking that doesn't matter? The engine will get hot regardless of what the thermostat does, all it does is allow the hot liquid to reach the radiator to get cooled, right? I'm not sure which course of action to take next. All I know is that both hoses have cold coolant in them. The truck has been running for a half hour.
Old Dec 6, 2012 | 11:23 AM
Ianmattf100's Avatar
Ianmattf100
hey guys I don't mean to steer away from topic but I have some type of coolant leak that drips from around my heater box to the passenger side floorboard. What is this? I dont even need a heater. should I take it out or why is coolant leaking...so confused.
Old Dec 6, 2012 | 12:04 PM
Boss9F100's Avatar
Boss9F100
The valve is probably stuck in closed position. Replace valve. There is a proper way to connect which hose goes where to heater core also but would still work if crossed. No matter what temp the engine is at the coolant should go thru the heater core if that valve is open. Non deluxe heaters did not have the valve so you could bypass it for time being. Just put nipple in and try and when you can install the new valve.
If heater has been inop for a long time expect to replace heater core anyway. Like last poster his heater core is leaking.
Old Dec 6, 2012 | 12:05 PM
Boss9F100's Avatar
Boss9F100
Your heater core is leaking. Replace with copper brass as the aluminum ones are junk and lines too short. Should be 29.00 to 60.00 max. for heater core
Old Dec 6, 2012 | 12:07 PM
Koamileli's Avatar
Koamileli
Anyone know what the stock or recommended temp range should be for the thermostat on this engine? It's a 352 3 speed 2wd. 1965.
Old Dec 6, 2012 | 12:36 PM
Boss9F100's Avatar
Boss9F100
192 or 180 would be fine for your location.. prob the 192
