Hello, Forum - My vehicle is an 1989 Aerostar, EB extended with a non-RBS or non-ABS brake system. Also, my braking is system is stock; no special pads or performance parts.
Problem - My brake metering/proportional block has developed a leak at the nut between the two input lines on the top of the unit.
I've been calling around and there doesn't seem to be a replacement part available up here in Canada. Before I try reefing on that nut or taking it apart (can't find any non-antilock information on it in my Ford manual) can anyone shed some light on this gizmo. Perhaps someone with a 1988 or earlier Ford shop manual has a section covering this part. I've read some of the posts, but they refer to the antilock system not my old standard type.
Hello, forum - Thanks for your quick replies and diagram - you guys are great. I've managed to find a NOS part from Green Sales in Cincinnati, OH and it's getting FedEx'd up here quickly.
Great suggestions - But, I would hesitant to use a junker replacement part for my brake system, it could fail sooner then later and need another one. Teflon tape could work for a temporary fix, but, I wouldn't want to depend on it for long. I drive in and out the mountains up here, so, I'm very safety conscious about my brakes.
I've noticed this part has been a common failure because of internal corrosion over 20+ years operation on our Aeros. I was considering eliminating the part and just hooking up a adjustable valve on the rear line, but it'll be nice to R/R the part and maintain the designed safety feature.
Due to the high center of gravity, most trucks undergo a lot of weight shift during braking, so they all need some kind of dynamic pressure reducer (or ABS) to keep the rear brakes from locking up. An adjustable pressure regulator would have to be set to very low pressure to reduce the chance of locking up the rear brakes under hard stops. But that means they'll be less effective under less-hard stopping conditions.
Yup - got 'er done today. Installed NOS proportioning/metering block and bled brake lines. Used the ol' Mity Vac - worked like a charm. All bleeders valves and brake line fittings seized - not rusted, but 23 years attached. Thank God for PB Blaster, good stuff. Now, time for a couple of reward beers and still no hockey - Damn you, NHL!!!
