Need help lowering the '72!!
Old Dec 8, 2012 | 04:37 PM
72Truckin's Avatar
72Truckin
Originally Posted by HIO Silver
Those look like adjusters for the overload or "helper" leaf springs. Yes, it will adjust the ride height but only to compensate to level the truck when there's a pallet of bricks in the bed.
So which of the two packs of leaf springs are the helper springs; top or bottom?
Old Dec 8, 2012 | 05:37 PM
HIO Silver's Avatar
HIO Silver
Top... the ends of that spring pack (I am assuming) make contact as the load increases with that adjustable doohickey bolted to the frame.
To verify, a better pic to show us would be from the rear pointing forward and between the frame and the tire.
Old Dec 8, 2012 | 08:50 PM
72Truckin's Avatar
72Truckin
Old Dec 8, 2012 | 08:58 PM
72Truckin's Avatar
72Truckin
Additional pics
Old Dec 8, 2012 | 09:13 PM
HIO Silver's Avatar
HIO Silver
Additional pics
Atta boy.... Yessiree... that's a helper/overload spring.
I think your set up also has an add-a-leaf... it's the bottom-most leaf under the bottom spring pack. Someone will correct me if I'm spacin'.
Also, your rig is equipped with "Flexo-matic" spring hangers (three bushings). When overloaded, the lever action moves the fulcrum point forward and makes the leaf spring pack behavior shorter and thus, stiffer.
Old Dec 8, 2012 | 09:30 PM
72Truckin's Avatar
72Truckin
So how do these new findings help or hinder my plan to lower the rig?
Old Dec 8, 2012 | 09:46 PM
BobbyFord's Avatar
BobbyFord
If you want to lower the rear by 5" then take the helper pack off of the top and toss them. Get a filp kit bracket from AIM and relocate the diff to the top of the factory spring pack. This will require a c-notch, shorter shocks and a bracket on the diff shock mount to adjust the shock angle (or a relocation of the upper shock mount).
Old Dec 8, 2012 | 10:00 PM
72Truckin's Avatar
72Truckin
I just need to lower it like 3.5" in the rear and 2" in front
Old Dec 8, 2012 | 10:11 PM
HIO Silver's Avatar
HIO Silver
Flip the front spring hangers of the rear leaf springs... Cost: About $15 for new Grade 8 bolts, washers, and nylon locking nuts.
Removing the rivets is the hardest part. Cut an X on the heads and then use a cold chisel to break 'em off. Grind flush. Then use a center punch and a BFH to drive 'em out.
Turn 'em upsy-down, mark and drill new holes. Install and voila!... about 3 or so inches of drop.
Old Dec 8, 2012 | 10:22 PM
72Truckin's Avatar
72Truckin
HIO, no need to remove helper spring?
If not, then I'll take care of this mod before the end of the month.
Old Dec 9, 2012 | 11:45 AM
HIO Silver's Avatar
HIO Silver
Take a bit to study that rear suspension. If the spring hanger is flipped, then the relative position of everything changes.... including the helper spring. See? Then it will make contact with the frame-mounted stop.
The helper leaf pack will need to be removed to do the spring hanger flip.
Old Dec 9, 2012 | 01:45 PM
BobbyFord's Avatar
BobbyFord
Before doing the hanger flip, I recommend measuring the pinion angle. You will need shims after the hanger flip to correct the pinion angle.
Old Dec 9, 2012 | 01:59 PM
  #28
HIO Silver's Avatar
HIO Silver
Visually.. pay no mind that it says "front axle". The principle remains the same:
Old Dec 10, 2012 | 04:37 PM
  #29
72Truckin's Avatar
72Truckin
Perfect! I will attempt this next weekend
Old Dec 10, 2012 | 04:38 PM
  #30
72Truckin's Avatar
72Truckin
Additionally, I am supplying another pic, for those who have not seen a flexomatic setup
