Sponsored by: Auxito
Im looking for some help.
Old Dec 3, 2012 | 09:15 PM
Chrisstorm's Avatar
Chrisstorm
A 97 f150 4.6L. The truck has some issues going on with it right now. The wipers do not work. They have power to the wiper motor but nothing happens. Changed out the wipes switch on it. That didn't work when i put the original back in 3 things happened. 1. the as light keeps flashing 2. No stop lights work 3. U can not shift out of park when truck is running or if key is in running position. Now before al this happened the wipes used to keep running for a bit after you shut them off. So right now Im looking for the location of a really. The relay is.... 1997 Ford F-150 SMP Windshield Wiper Motor Relay. And any advice or help would be appreciated thank you. Chris
Old Dec 4, 2012 | 05:45 PM
vaper's Avatar
vaper
Not sure on the abs? light but the brake lights and shifter interlock
will probably be related.
Did you maybe pull a wire off the brake light switch at the pedal when you installed the multiswitch?
Or caused a short to burn the brake light fuse?
The original problem with the wipers was they wouldn't shut
off?
When they did stop did they park properly?
Sorry I don't know where the relay is
Hope this helps a bit
mdwilkins
13
Jul 9, 2020 03:47 AM
JavaDaddy
21
May 6, 2019 04:34 PM
Blueman2
Nov 26, 2011 12:17 PM
pfeifer5
1997 - 2003 F150
Jul 11, 2008 06:14 PM
brian_06328
Electrical Systems/Wiring
Jan 23, 2004 12:03 PM
