Rear Transfer case
Old May 23, 2003 | 04:05 PM
mpalamaras's Avatar
mpalamaras
Rear Transfer case
I have a 79 f250 and I am curious how I can tell what my rear transfer case is. is it a Dana 60 or 44 or what? I am new at this stuff so any help is appreciated
Old May 23, 2003 | 06:48 PM
steve83's Avatar
steve83
Rear Transfer case
Well, a truck generally only has 1 t-case, and it's generally in the middle of the truck. The D60 & D44 are "axles". If you need to know about the t-case, look here. For axles, look here or here.
Old May 23, 2003 | 07:47 PM
mpalamaras's Avatar
mpalamaras
Rear Transfer case
Thanks, I meant axle. As I said I am new to this. ONe of your links for axles did not work. So judging by the one link I can measure the size and shape and I should be able to tell whether it is Dana 44 or Dana 60?
as I mentioned it is a 79 f250 and I am quite sure it has not been changed.
Thanks again
Old May 23, 2003 | 09:35 PM
steve83's Avatar
steve83
Rear Transfer case
Yes, you should be able to ID it just by looking at the shape of the rear cover. I doubt an F-250 would have a D44, but if it DOES have a Dana axle, and you can find the bill of materials number, you can look it up here.
Old May 23, 2003 | 09:38 PM
mpalamaras's Avatar
mpalamaras
Rear Transfer case
Why do you dobt a Dana 44? What would you think it should be?
Old May 23, 2003 | 09:40 PM
steve83's Avatar
steve83
Rear Transfer case
Something stronger, like a D60, but I'm not familiar with pre-'80 trucks. Maybe these guys would know.
Old May 24, 2003 | 12:07 AM
77'F-150Mudder's Avatar
77'F-150Mudder
Rear Transfer case
The easy way to tell is by looking on the diff just below and to the right (or left, cant remember) of the differential cover. On the little triangular shaped webbing. Dana 60 will have a "60" cast there, a Dana 44 would have a "44", etc.
Not that's it's not possible, but I've never heard of an F-250 having a Dana 44 out back. Ocassionally you hear of a guy who claims to have a factory D44 rear in his F-150 or F-100, but I'm even skeptical about that. I'm not saying that it's not possible though.
Old May 24, 2003 | 11:49 PM
deere81's Avatar
deere81
Rear Transfer case
You should have a dana 44 front axle and a dana 60 rear axle.
Old May 26, 2003 | 06:45 AM
Megalomaniac's Avatar
Megalomaniac
Rear Transfer case
It's a Dana 44 differential with larger parts at the wheel, including a matching 8 lug pattern.
Megalo...
blue924.9
Mar 5, 2013 07:13 AM
EASTSIDEAUTO
Jan 13, 2012 05:19 AM
oldirtytruck
Mar 15, 2009 09:45 PM
bigjohnsonross
Feb 23, 2009 01:23 PM
redneckford_68
1983 - 2012 Ranger & B-Series
Apr 11, 2005 12:58 PM
