1978 - 1996 Big Bronco
BACKFIRE! BACKFIRE! BACKFIRE!
Old Dec 2, 2012 | 06:53 PM
sohaggard88's Avatar
sohaggard88
Hey all. Hope everyone is enjoying their weekend thus far. I know I am. Especially when the Redskins win tomorrow. lol
Anyways, I have a:
1988 Ford Bronco FS
5.8 351W
The truck is just about as stock as can be so far.
So I bought this truck about a year and a half ago. It sat a whole year and now I am having problems... of course.
Today I did a tune up:
Spark Plugs, Wires, Distributor cap, Rotor, ignition coil and fuel filter.
EDIT! After a few seconds of holding the pedal, all runs GREAT! like nothing wrong. Only sluggish when I initially push on the throttle....
Prior to the work I did, when I would slam on the gas, it would be very sluggish and then back fire through the intake. If i dont press the pedal hard, its sluggish but doesnt back fire.
Well after all the work done today, ITS STILL DOING THE SAME THING!
So any idead guys?
Thanks
Bobby
Old Dec 2, 2012 | 09:14 PM
njneer1's Avatar
njneer1
Check your firing order to make sure you didn't cross a plug wire
Old Dec 2, 2012 | 09:56 PM
sohaggard88
triple checked all of that already.i ordered a fuel pressure regulator to try that. anything else?
Old Dec 6, 2012 | 12:18 AM
Torky2's Avatar
Torky2
Sounds like it is running very lean.
A Fuel delivery problem, check fuel pressures.
OR
a tip-in throttle lean problem. Carb'd engines had the accelerator pump to richen the mixture when the throttle was opened, to cover the sudden lean condition caused by more air, before the regular carb jetting mixture function could respond.
In a FI engine of this vintage, the MAP sensor is one of the computer inputs for mixture. And so is the throttle position, both where it is, and how fast it is moving. If the TPS has a problem, even a scratchy area in its resistance, the computer misses the sudden opening of the throttle, so it goes lean, until the MAP sensor input catches up with it.
Gives you some things to check.
Old Dec 6, 2012 | 10:35 AM
Kemicalburns's Avatar
Kemicalburns
before you go buying parts you should pull codes. this motor is efi right?? are you sure plug wire 7 & 8 arnt crossed at the plugs themselves. what plugs are you running and what gap are they at? did you put new clean fuel into the tank? the fuel filter on the frame rail is probably needing replaced as well.
Old Dec 6, 2012 | 02:28 PM
greystreak92's Avatar
greystreak92
In addition to what Kem et al have already mentioned, have to checked your base timing? When you do, make sure the engine is at full operating temperature and the SPOUT connector is removed.
Old Dec 6, 2012 | 06:18 PM
sohaggard88
the plugs are autolite platinums and whatever gap were on them is on it. i changed the fuel filters. i checked the timing and its fine. i dont have a way to check the pressure currently, so whats some ideas to check the map and throttle position sensor without actually replacing?
Old Dec 6, 2012 | 06:19 PM
sohaggard88
i unplugged the throttle position sensor and its exactly the same
Old Dec 6, 2012 | 08:35 PM
greystreak92
Unplugging sensors arbitrarily will only cause fault codes to generate in the ECM and won't answer the questions. Pull fault Codes using either the KOEO or KOER tests.
Old Dec 6, 2012 | 08:50 PM
sohaggard88
can u tell me a few ways to do them. im a rookie and more or less are clueless. lol
Old Dec 7, 2012 | 12:17 AM
greystreak92
Check this site.
Old Dec 7, 2012 | 09:39 AM
Kemicalburns
when you set the timing did you use a timing light an pull the spout connector like Grey mentioned. Plantinum plugs also dont run well in our rigs
jacampbell
Nov 4, 2018 09:29 PM
Cam Strader
Oct 25, 2017 03:35 PM
tenderfoot
Dec 27, 2004 04:35 PM
delasouza
Nov 25, 2004 01:44 PM
tyson1992
Nov 26, 2003 11:58 PM
