Sponsored by: Kumho
brake issues
Old Dec 2, 2012 | 06:36 PM
btracy's Avatar
btracy
brake issues
i have a 79 f150
i changed two brake lines and master cylinder and bleed,and more bleed,but still very soft all most to floor? wheel cylinders look good.
Old Dec 3, 2012 | 12:40 PM
Beechkid's Avatar
Beechkid
1. still have a stubborn air bubble floating in the system
2. The new master is defective
Old Dec 9, 2012 | 04:28 PM
crop harvester's Avatar
crop harvester
try clamping one at a time all four brake calipers or wheel cylinders hoses, if that dont yeild better pedal,then try bleeding master cyl. be careful when bench bleeding mc not to push piston to far some can be damaged,as far as the piston cups. if you bleed to long you will create to many air bubbles then you need to take a break.
clr0gers
1947 and Older Ford Trucks
Jul 7, 2014 08:26 AM
Ole 64
Jan 4, 2012 08:31 AM
mick460
Garage & Workshop
17
May 2, 2004 08:08 PM
chmuraman
Mar 11, 2004 06:06 PM
