Wheel Hub
Old Dec 2, 2012 | 02:08 PM
Htc102410's Avatar
Htc102410
Wheel Hub
I have a 1993 f-350 crew cab dully. It is also RWD!! I'm having trouble find a front wheel hub. I can find the single rear axle hubs all day but can't not seem to find one for dual rear wheels. If anyone knows where I might be able to find one beside ordering the whole assembly!
The hub I'm looking for bolts onto the rotor on one side and has the lug bolts on the other. It's not the pressed one.
Any advice will help!!!
Thanks,
Chris
Old Dec 2, 2012 | 03:35 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Just to be clear, you are looking for this right?
These are also the ones your looking for, that bolt to the rotor from the back.
Any Dually Ford truck, or even van will be the same. As long as it's 2wd in your case.
I'm sure you'll find an old Cube van, motorhome, or dually truck in the junk yard.... you'll have to look around.
pavementpounder96
30
Jul 12, 2022 03:35 PM
Jasonnoel
Nov 30, 2018 03:24 PM
78pace
Feb 23, 2011 09:52 PM
JohnAW
General Automotive Discussion
Mar 14, 2005 03:17 PM
Home Solutions
Nov 16, 2004 06:13 AM
