Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Horn button
Old Dec 1, 2012 | 02:00 PM
1930 Dodge's Avatar
1930 Dodge
Horn button
Does anyone have a spare horn button for a 52 F-7 truck? I am guessing that it is not the same button as a smaller version truck because of the overall larger diam of the steering wheel? Maybe someone will correct me if I am wrong on that.
Also does anyone have a diagram or able to tell me how the horn is supposed to operate. I have the wire coming out the bottom of the steering box and see the button area as the switch but where does all of this receive its power.
No horn mentioned that I am able to see within the shop manual wiring diagrams. Thanks
Old Dec 1, 2012 | 03:36 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ask this question in the 1948/56 truck forum.
B2TZ-13A805-A (replaced 7HC-3627-C) .. Horn Button / ALL 1948/52 / Obsolete/Reproduced ~ Listed in Carpenter's 1948/56 truck reproduction parts catalog as 7HC-3627-C @ $18.00.
Carpenter's repro parts catalog is free, call 800-476-9653 and ask for the puppy.
The 1948/56 Ford Truck Parts Catalog is available on a CD from hipoparts.com for about 22 bucks.
Or, you can buy a new bound paper catalog from Carpenter for 200 bucks.
Old Dec 2, 2012 | 05:04 AM
1930 Dodge's Avatar
1930 Dodge
Thanks for that, at 18 dollars I will purchase
Old Dec 2, 2012 | 05:36 AM
1930 Dodge's Avatar
1930 Dodge
I was able to look on-line catalog and that is it, I am really surprised that they used the same button on all models but again thanks. Can you tell me how these original horns received their power or how they operated?
Old Dec 2, 2012 | 06:16 AM
NumberDummy
Ask this question in the 1948/56 truck forum. You'll get more help there, with catalog and shop manual pics, info from members that own like trucks.
I cannot answer your question as I've never owned a 1948/52. I haven't a chance of fitting in the cab (6-5 300).
Old Dec 2, 2012 | 07:48 AM
1930 Dodge's Avatar
1930 Dodge
I believe I may have figured out how the wiring is supposed to go for that horn button but thanks though
Old Dec 3, 2012 | 05:15 AM
big job's Avatar
big job
wiring
Hi I replyed to this post on the other forum and correct same button as a
pickup except the retainer (under the steering wheel bolt) Its really the
same, but the hole is larger on F7 & F8s.
Old Dec 3, 2012 | 11:45 PM
1930 Dodge's Avatar
1930 Dodge
Hello Big Job, so correct me if I am misunderstanding but the horn buttons are not the same ( ? ) in other words this horn button that I am ordering thru Carpenters catalog will NOT fit as it should ? Thanks for the heads up if this is the case, I guess I should be glad I did not get home in time today to order it if that is the case.
billdoss2
Dec 8, 2016 06:49 PM
jrk3332
Large Truck
May 25, 2015 01:02 PM
sonny1965
Jun 24, 2014 04:42 PM
P38fighter
May 24, 2014 07:28 AM
kjhales
Mar 30, 2013 06:31 AM
