my 97 truck has something up
went to start it and it would start and die start and die.got it running and home and then it wouldnt die lol had to pull a fuse to kill it.
i'm thinking the swith on the column.anything else that could cause this?
thanks john
One possibility, a bad GPR can cause the truck to keep running with ignition key OFF. Some internal short thing can cause a feedback to keep the PCM powered up. Read about it a few time here on FTE.
No like i didnt turn the key off.most everything else shut's off but the motor stayed running till i pulled the fuse.started it back up and same thing.I'll change the GPR tomorrow and see.i think it's not doing anything anyway's
Thanks john
