No cabin heat
Old Nov 30, 2012 | 02:44 PM
Lallone's Avatar
Lallone
No cabin heat
Hi guys
I drive an 05 f250 and the heat doesn't come out of the registers or the feet just out at the windshield. What could be the problem?
Thank you
Old Nov 30, 2012 | 02:47 PM
2006lariat's Avatar
2006lariat
Vacuum leak. If it is a diesel, check around the oil cap. There will be a heater hose that will have a Vacuum valve in it, Make sure the vacuum hose is on it. If it is a diesel check hoses around pump, and if it has automatic hubs check them vacuum lines too. If it is a gasser, check vacuum lines.
Aaron_Jones
Dec 6, 2016 08:14 PM
pmoney1983
Jan 16, 2013 03:57 PM
jest2525
1997 - 2003 F150
May 10, 2011 10:58 PM
LARIAT 85
May 24, 2007 07:59 PM
kenfyoozed
Apr 26, 2004 11:19 PM
