Headlight Harness
Old Nov 29, 2012 | 08:54 PM
Shadowrider123's Avatar
Shadowrider123
Headlight Harness
I installed the LMC headlight harness on my 66 this evening.
What a PITA. Not the harness, all the rusted, stripped, and missing screws in my truck.
Finally got it all done, another 20 minute job that took 3 hours.
The lights work great, they will work even better when I get a matched set of headlights.
I was wondering, are my headlights fuse protected now or did the LMC harness eliminate the fuse protection?
Should I install a couple inline fuses on the power wires?
Im sure LMC sells bunches of these kits, Im surprised that there were no fuses.
Old Nov 29, 2012 | 09:24 PM
Jetcopterpilot's Avatar
Jetcopterpilot
should be on the fuse block under the dash! mine are!
Old Nov 30, 2012 | 05:10 AM
jowilker's Avatar
jowilker
Want to see a real improvement, check out the Whiter Brighter lights tech article on this site.
John
Old Nov 30, 2012 | 09:16 AM
37 Ford guy's Avatar
37 Ford guy
John
I assume you mean this one, John? Whiter Whites, Brighter Brights .: Articles
Old Nov 30, 2012 | 09:26 AM
ol yeller's Avatar
ol yeller
While your at it clean the connections on your dimmer switch. When they act up your lights will flicker or go off at a bad time.
Old Nov 30, 2012 | 09:31 AM
daveengelson's Avatar
daveengelson
The fuse block on my 65 has never had a fuse for the headlights??
Old Nov 30, 2012 | 04:36 PM
jowilker's Avatar
jowilker
That beeees the one. It's not expensive but puts hotter current to the bulbs. I did it 10+ years ago.
John
Old Nov 30, 2012 | 09:48 PM
tbm3fan's Avatar
tbm3fan
Looks like this under the battery
Old Nov 30, 2012 | 11:06 PM
Shadowrider123
Mike
1965 F-100 360-2V
1968 Cougar 302-4V
1968 Mustang 289-2V
1967 Parklane 410-4V / 1973 Dodge Polara
1943 USS Hornet/1945 TBM3E Avenger
How does one come to own an Avenger?<!-- / sig -->
Old Dec 1, 2012 | 07:56 PM
tbm3fan's Avatar
tbm3fan
Mike
1965 F-100 360-2V
1968 Cougar 302-4V
1968 Mustang 289-2V
With $90,000 is how one might get one in 1998. The museum purchased the plane and asked me to take charge of restoring it back. So I did the exterior, which was easy, despite having to learn how to fabricate aluminum panels and cowlings. The interior took 4 years just to locate all the missing pieces there during WWII. The bomb bay doors took 12 years to locate after checking out ever rumor on the warbird grapevine. Then found TWO sets in Idaho, jumped into a truck, drove out and got them. Unfortunately, I have stopped working on the plane, after exterior painting, in 2003. I have way too much work to do in saving and restoring the Island superstructure right now.
ericconn
Dec 2, 2013 09:44 AM
Diesel_Brad
Aug 6, 2009 10:08 PM
cbrnflt
Electrical Systems/Wiring
Dec 20, 2006 08:59 PM
