Im having a problem with my 5-Speed ZF. I know its not chattering because its a brand new south bend clutch and pressure plate, but when im in a gear and hitting no gas, there is a sound very similar to a clutch chatter coming from below my seat. The engine RPM are at idle. If im going down a hill its not there, if im going up or under load it can get pretty bad. Its not slipping however. Doesnt really do it on a normal take off, but when trying to start on a hill or while hauling i can really hear it, not so much feel it. What could this be? It didnt do it the first week i owned the new clutch, i run my truck pretty hard but almost never slip my clutch, i do downshift though
If you have not had an SMF before, this is most likely your issue. It's a normal thing.
Ok thanks, ill dump a bit more in and see what happens. It wont bother me as long as i know its not bad for it, i dont mind the noise, my straight pipe and stacks drown it out, i just dont wanna mess anything up
An extra qt wont be to much for sure. I think I have an extra 2 in mine, but I'm not sure anymore.
Is it possible the problem would be the carrier bearing on the drive shaft, since op says noise is coming from below his seat?
