Sponsored by: Auxito
2000 F150 Headlight Problem
Old Nov 29, 2012 | 06:20 PM
makthenif's Avatar
makthenif
The brightness level suddenly went down on the left headlight. I replaced the bulb but that still did not correct the problem. I have no idea what might be causing this problem. Any advice would be appreciated.
Old Nov 29, 2012 | 06:47 PM
Bluegrass 7's Avatar
Bluegrass 7
Low brightness is low voltage.
A ground issue perhaps dropping to much voltage accross it from the current flowing.
Each side has a seperate fuse so it's not normally a fuse doing this.
At the poor ground point, voltage accross the poor connection goes up as the resistance goes up.
When it approches about half the system voltage or 12/2 = 6 volts the lamp dims from half the voltage it should have..
Good luck.
Old Nov 30, 2012 | 08:46 AM
makthenif's Avatar
makthenif
Good luck.
What? So what is the fix?
Old Nov 30, 2012 | 11:01 AM
RebColonel's Avatar
RebColonel
Check the ground wire from the bulb back to where it grounds, then clean the ground connections.
Old Nov 30, 2012 | 11:48 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
check the plug that plugs into the bulb. Also is the lense hazy or have water built up in it?
Old Nov 30, 2012 | 06:07 PM
projectSHO89's Avatar
projectSHO89
The "fix" is to find and repair the high resistance in the circuit. Most commonly, it is a corroded connection.
Old Dec 1, 2012 | 09:07 PM
thecardoc's Avatar
thecardoc
The plug that plugs on to the bulb itself is common failure especially if high wattage bulbs are used.
Kilomanjaro
Feb 23, 2022 12:14 PM
1ole4d
Electrical Systems/Wiring
Apr 4, 2017 10:52 AM
EricMJohnson
Nov 25, 2013 06:45 AM
charlie59701
Jul 9, 2010 09:11 AM
60FordDriver
Jan 24, 2008 10:38 PM
