Ignition Coil Replacement
Old Nov 29, 2012 | 04:10 PM
EJMoosa's Avatar
EJMoosa
I have a 99 Expedition 5.4 engine. I am attempting to replace the second ignition coil from the front on the right side of the engine. I cannot get it to seat whatsoever.
I uninstalled the front coil and placed the new coil there and it seats without an issue. So I tried to seat the older coil in the second position, and it will also not seat.
I have lubricated the coil, with no success.
Any suggestions?
Thanks in advance.
EJ
Old Nov 30, 2012 | 02:17 AM
alloro's Avatar
alloro
Is the correct spark plug installed or is the plug possibly broken?
Old Nov 30, 2012 | 07:54 AM
EJMoosa's Avatar
EJMoosa
Broken plug
I did see what I think now is indeed the top of a spark plug, which is restricting the seating of the ignition coil.
Seems I should take it in and have all eight changed. I am not sure how difficult it is to change the plugs on this vehicle. I will look and see what is involved and call around to see what that may cost.
Thank you for suggesting that possibility.
Old Nov 30, 2012 | 08:00 AM
pinellas50's Avatar
pinellas50
There isn't more to this story is there? ie a spark plug blown out of the cylinder head?
Old Nov 30, 2012 | 08:04 AM
EJMoosa's Avatar
EJMoosa
I think that is what I am dealing with. Just did a brief search on that and now I fear this is going to be much more expensive than I imagined.
Old Nov 30, 2012 | 12:54 PM
r2millers's Avatar
r2millers
EJ,
You will find most shops will charge you around 200 bucks in labor to change them out. It is a pain to get to the back two plugs on each side but with several extensions, remove the engine plastics, some twine to pull your heater hoses back, and some patience, it can be done in a couple of hours.
The good thing is you don't have 2 piece plugs to break apart. Use anti-seize on the plug threads and dielectric grease on the coil packs.
Old Nov 30, 2012 | 07:34 PM
alloro's Avatar
alloro
You must've got real lucky with a repair shop around you. Most places charge $600-$700 to replace the spark plugs. They also charge $20 per spark plug making just the materials $160.
Old Dec 4, 2012 | 08:40 AM
EJMoosa's Avatar
EJMoosa
Final Tally
Picked up the Expedition this am.
They used a cylinder head repair kit on the cylinder where the plug blew out. So this cylinder now has a longer plug, and a shorter ignition coil installed.
They went ahead and changed the rest of the plugs and ignition coils, as well as replaced the PCV hose assembly, which I knew was showing it's age.
Final cost with labor: $549.
Thanks for the responses and advice. I am glad to have found a great shop, which was recommended by a friend.
EJ
Old Dec 4, 2012 | 10:38 AM
r2millers's Avatar
r2millers
and I'm in So Cal where nothing comes cheap! Most use the standard Chilton labor guidelines and charge that job times their hourly rate. 549 for the plug removal and new plugs plus labor seems reasonable.
Old Dec 4, 2012 | 11:10 AM
alwaysfords41's Avatar
alwaysfords41
It's in the ball park. $200 is not.
Old Dec 5, 2012 | 03:18 AM
alloro's Avatar
alloro
So why did you mislead him up in post #6 by saying, "You will find most shops will charge you around 200 bucks in labor to change them out"?
Old Dec 5, 2012 | 11:16 AM
r2millers's Avatar
r2millers
alloro
Mislead????
Did you read his complete message???
"They used a cylinder head repair kit on the cylinder where the plug blew out"
Did you think this was free???
The 200 bucks didn't include having to do the ADDITIONAL work as noted.
Mislead??? Come on!
Do your homework first please.
darcrysd
Sep 1, 2014 09:44 PM
eigenvector
1983 - 2012 Ranger & B-Series
Aug 26, 2006 08:35 AM
Jrock909
Aug 12, 2006 03:18 PM
Fine250
15
Sep 11, 2005 01:06 AM
rodhuffaker
Mar 1, 2004 05:03 PM
