Modular V10 (6.8l)
V10 tune up?
Old Nov 28, 2012 | 08:19 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
V10 tune up?
My work van is a E350 with 165k on it & was wondering what would you replace at that milage? I did plugs & tramsmission fluid @ 100k, thanks in advance.
Old Nov 28, 2012 | 09:59 PM
jh818's Avatar
jh818
I assume you have done regular oil changes.
I would do coolant/radiator flush, differential oil change, air filter, clean MAF sensor, clean throttle body, brake fluid flush, power steering fluid flush, fuel filter change.
I would do the plugs/boots and trans fluid again, too.
How are the shocks? Serpentine belt, tensioner and idler pulley?
These are what I can think of off the top of my head.
Old Nov 29, 2012 | 06:39 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
What would you clean the maf sensor/throttle body with? Good idea with the belt, its squealing (i keep the old one just in case). I just replaced the shocks with some super heavy duty monroe's. What do you mean by the boots? thanks Curt
Old Nov 29, 2012 | 08:34 PM
jh818's Avatar
jh818
Clean the TB with carb cleaner suitable for O2 sensors.
You can get a spray can of MAF sensor cleaner from any auto parts store. CFC brand comes to mind.
Boots are those rubber sleeve over the spark plugs with the spring inside. They tend to crack over time and allow water to get into the hole causing misfires.
Texan481
2004 - 2008 F150
13
Jul 10, 2022 09:26 AM
siamesegun
Escape & Escape Hybrid
Dec 1, 2010 04:35 PM
darkmindzz
S. California Chapter
May 21, 2009 12:00 PM
Blown240
1997 - 2003 F150
Aug 3, 2007 06:22 AM
pitrow
Sep 15, 2005 10:36 PM
