Hey fellas. I have a 2005 STX with the 4.6L, 4WD, AT.
The engine has started to make a loud whining sound recently. I replaced the belt and tensioner since it was original and had 93,000 miles on it. The sound is still there.
The sound increases with rpm but doesn't change when you turn the steering wheel.
The engine starts and runs smoothly with plenty of power.
All the time, or just for several minutes when it's cold? If the latter it may be an alternator bearing issue. Mine does that when it's cold out... I'm not going to do anything unless it craps out. The noise goes away as soon as it warms up a little.
My truck does the same thing - the whine is only present when it is about 35 degrees or colder. Had it last winter, went away all spring and summer, and just started back up again the past few weeks.
I think it is a vacuum leak. Because the truck runs fine I haven't bothered to investigate further.
The idler pulley on the driver's side was bad. Easy fix with a third hand. Thanks.
While investigating the problem and repair I noticed the idler pulley on passenger side had only a minor amount of wear and the belt doesn't fit tightly against it. Is this normal?
The belt might have an odd shape in it now if the driver's side pulley was out of balance for a while. Might not hurt to replace that as well..
