351W In 76
Old May 22, 2003 | 11:15 PM
79 390 highboy's Avatar
79 390 highboy
351W In 76
how easy would it be to pull a 390 in a 76 and drop a 351w in place. Are the motor mounts different. And is there nething special to be done. And can a T-19 bolt up to a 351w.
Old May 22, 2003 | 11:33 PM
Torque1st's Avatar
Torque1st
Posting Legend
351W In 76
The bell housing bolt pattern is different between the 390/FE series engines and the small block 302/351W series.
With proper bell housings the T-19 will bolt up. WHere were you able to find a T-19? These trucks usually came with a T-18.
Old May 23, 2003 | 12:58 PM
79 390 highboy
351W In 76
whats the difference between a t18 and t19
Old May 23, 2003 | 01:09 PM
Torque1st's Avatar
Torque1st
Posting Legend
351W In 76
The T-18 has an unsynchronized "granny" first gear. It was used in light trucks (F150-350) and meant to be started out in second gear for normal driving.
The T-19 has 4 synchronized gears, none of them a "granny" gear. It was used in "Box" trucks, school bus aps, and other medium trucks.
Externally both transmissions look the same.
Old May 23, 2003 | 02:52 PM
79 390 highboy
351W In 76
ok so i guess i have a t18. But still the question at hand is it hard to but a 351w in a 390s spot
Old May 23, 2003 | 03:34 PM
supercab4x4dually's Avatar
supercab4x4dually
351W In 76
This i did on my first truck ever and all i had to do is use the motor mount's from a 79F150 2wd and changed the bell housing to fite the 302/351w and used the 2wd clutch and flywheel setup,and The exhuast I used flowtech shorty header's for a 85 F-250 and made up some custom exhuast,and my own 2 cent's I loved my 302 it did more trailer towing,snowplowing,and some 4wheeling and that babey never let me down,we took it out of the truck it was in and 8 yr's later it still power's a street worior/pro arena truck that we run.But back to the swap,not bad at all.
