another bad injector
Old Nov 25, 2012 | 05:28 PM
gene17847's Avatar
gene17847
hi my 6.0 with 277k every time i change the oil i jrop a injector and i change the oil every 6,000 can anyone tell what i can do to stop this short of replacing all 8 injectors
Old Nov 25, 2012 | 05:37 PM
mustang_309's Avatar
mustang_309
What oil and filters are you using, and are the injectors you are replacing original?
Old Nov 25, 2012 | 05:41 PM
Lilpooh's Avatar
Lilpooh
Are you monitoring FICMv and Fuel psi? What brand fuel filters?
Old Nov 25, 2012 | 05:55 PM
gene17847's Avatar
gene17847
i use rotella oil and fram filters
Old Nov 25, 2012 | 06:00 PM
dannyboy950's Avatar
dannyboy950
Replaceing the injectors is the end result of your problem not the cause. Have you cut your filter open and visually looked at what might be in there.
Really dirty fuel with particles smaller than the micron size of the filter will go thru the filter and into the injectors themselves.
Old Nov 25, 2012 | 06:17 PM
Lilpooh's Avatar
Lilpooh
Yep, damaged injectors are usually the end results. So what is your FICMv and Fuel psi?
Old Nov 25, 2012 | 06:18 PM
gene17847's Avatar
gene17847
i have no way of checking those two
Old Nov 25, 2012 | 06:31 PM
Lilpooh's Avatar
Lilpooh
To diagnose and maintain the 6.0, a monitor solution is invaluable. You have choices, like ScangaugeII, Edge Insight, DashBoss.
ScangaugeII will take care of all the gauges needed except EGT and Fuel psi, you will need seperate analog gauges/pod for them.
DashBoss will monitor everything on one device with adding the EGT and Fuel psi to the Bluetooth OBDII adpter, this also requires using an iOS device (iTouch/iPad/iPhone).
Edge Insight CS/CTS will monitor everything on one device when you purchase the expandable cable for EGT and Fuel psi.
Take a look at the sticky section, lots of info regaurding how important a monitor solution is, not to mention it makes it easier to diagnose issue.
Old Nov 25, 2012 | 06:32 PM
BLADE35's Avatar
BLADE35
you need to install the blue Fuel Pressure regulator spring
droping injectors like you are is commonly from Low Fuel press
Most of us install the Blue FPR Spring just to be on the safe side
Old Nov 25, 2012 | 06:41 PM
Lilpooh's Avatar
Lilpooh
Some aftermarket fuel filters don't have or not the right outer membrane on the HFCM filter to repel/seperate water.
Old Nov 26, 2012 | 05:28 AM
gene17847's Avatar
gene17847
Will it hurt to drive it till i get a new injector in it
Old Nov 27, 2012 | 12:34 PM
fordtruckrodder's Avatar
fordtruckrodder
Most here are against using FRAM filters, and suggest only Motorcraft or RACOR. I am not sure but, maybe this is some of the problem.
Old Nov 27, 2012 | 12:46 PM
Abram's Avatar
Abram
Where is a good place to get the Edge Insight CS/CTS and can this replace my scII or do i still need to keep the scII for other readings. Thanks.
Old Nov 27, 2012 | 01:15 PM
Lilpooh's Avatar
Lilpooh
Sorry, can't help you there. I don't own either one of those, I use DashBoss for iOS devices.
The SGII will monitor more total PID's than the Insight. But the Insight will display more PID's on the screen than SGII. Any of the 3 that I mentioned have there pro's/con's. IMO, it's a matter of personal preferance.
If you got some cash burning a hole in your pocket and want a fancy display with other features, then decide if you want to buy the Insight. If not, then the SGII is more than capable of monitor/diagnose most issue that may arise.
Old Nov 27, 2012 | 03:00 PM
Abram's Avatar
Abram
I'm looking to get an EGT reading device..just wondering whats out there. So, by having these readings EGT and Fuel psi...what numbers should I look for to be on the safe side of things. Thanks.
