engine washing [beware!!]
Old Nov 25, 2012 | 05:23 PM
miottimouse's Avatar
miottimouse
Red face engine washing [beware!!]
ever get 50.000 or so volts shot at you through a pressure washer gun? i just did this morn and i am still feeling it!! i changed spark plugs in my s/c with the 460 last night and noticed the valve cover gaskets leaking so i took the truck to our shop to wash it a bit useing our 4000 psi hot water washer i used degreser 1st let it soak and started washing after i was done i started the truck and it was missing badly[thought it was water in the dist cap as usual] but i seen a spot i had missed and decided just to give it a shot well ZAP! owwy owwy it didnt take long to drop that gun! i collected my self and proceded to investigate and found i had knocked 1 spark plug wire off when the water hit it so next time i will double check that the plug wires are snapped on snug
Old Nov 25, 2012 | 05:32 PM
HIO Silver's Avatar
HIO Silver
Ummm... so the engine was running when ya decided to "touch it up"? Oy.
It's not that the voltage that will kill ya.. it's the current. Still, glad you're okay.
Old Nov 25, 2012 | 05:45 PM
POPAJON's Avatar
POPAJON
X2 on the you're
OK end.. AND amperage kills voltage burns. BUT in the end BOTH will kill you given the right situation. John
Old Nov 25, 2012 | 05:47 PM
gpence's Avatar
gpence
I've been power washing for years & never ran into that issue before & always leave the motor running in whatever Im washing. Gonna have to remember this!
Old Nov 25, 2012 | 07:01 PM
74 F350 SCS's Avatar
74 F350 SCS
Glad you're ok. I too have been power washing engines for over 30 years, sometimes with them running and sometimes not. Never had a problem but this is good to know!
Old Nov 25, 2012 | 07:27 PM
bucks77ford's Avatar
bucks77ford
Glad you are OK. Something that most if not all of us would think about when powerwashing our motors. I usually leave mine running too.
Crosma
1997 - 2003 F150
Dec 8, 2017 11:02 PM
cardone
1997 - 2003 F150
26
Nov 21, 2017 11:20 PM
405Ford
Modular V8 (4.6L, 5.4L)
Jun 15, 2016 05:56 AM
LilToe
26
Nov 15, 2011 09:01 PM
ditto
1997 - 2003 F150
Dec 5, 2007 11:50 AM
