48 F1 steering gearbox rebuilders?
My steering wheel moves about ten degrees before the output shaft starts to move on my 48 F1. I was going to pull it and rebuild it until i looked at the prices for the parts. Just the two shafts are $460 not including any bearings, gaskets or freight.
Does anyone sell a gearbox already rebuilt for less than that? Has anybody had any good or bad experiences with them?
Is there any one component that wears out in the stock gearboxes? Maybe I wouldn't need to buy both shafts?
The sector shaft itself isn't really a wear item; it's the worm gear and sector ball that get eaten up, as well as bearings. As far as I know, replacing the ball is all that's needed on the sector shaft. If you bugger the splines or threads on the sector shaft getting the pitman arm off, well...
The only reason for buying the whole worm gear/steering shaft combination is that the worm is shrunk on very tightly to its shaft. Replacement of just the worm is not for the feint of heart. (edit: looks like Allan did it, check his threads)
If you do an Advanced Search on this forum, there are several good threads about it.
You can get them rebuilt but its pricey. Below is a link to Sacramento Vintage Ford, just one of many who sell (exchange) them. I rebuilt mine and with research had no problems, I only needed the worm gear/shaft , bushings gaskets,ect, but not sector gear. Good luck. http://www.vintageford.com/part_sear...7174&Category=
adam83
10-24-2017 08:50 AM
F-1
05-08-2016 05:59 PM
eb4strom
09-20-2014 08:26 PM
50flathead
04-11-2007 12:50 PM
