Sponsored by: Auxito
Busted axle shaft boot
Old Nov 25, 2012 | 01:24 PM
BiltFordTuff's Avatar
BiltFordTuff
I have a 2003 Ford F150, 4x4, and i recently installed torsion bar leveling keys, i did not notice before i put the keys on, but while parked level, wheels straight, my wheels stand awkward, the bottom sticks out while the top is kinda sucked in, when i took a closer look, my inner axle shaft boot on my passenger side is busted and slinging all the grease out, has anybody had this same problem, what is the solution?
Old Nov 25, 2012 | 05:35 PM
coolguy1419's Avatar
coolguy1419
I had the same problem. Cranking the torsion bars up puts more stress on the cv shafts and boots causing them to split. You will need to put a new boot an repack with grease. You will have to remove axel shaft I believe. You may be able to do it with it still on I'm not sure. I took mine out. It's been a few years since I did mine. I know there is a little snap ring the holds the joint onto the shaft u pull that off an the boot will slide off and a new one can be put on. It's not a hard job to do just time consuming.
Old Nov 25, 2012 | 10:26 PM
BiltFordTuff
I figured as much, have you had any more problems after replacing the boots, i really dont want this to be a reoccurring problem
Old Nov 26, 2012 | 06:11 AM
coolguy1419
No the new replacement rubber is more flexible than the factory boot.
Old Nov 27, 2012 | 08:13 AM
00GT's Avatar
00GT
Where you from. I have 2 brand new aftermarket cv boots ill give you. I bought them for mine but ended up just replacing both cv shafts. They are much more flexible then the originals
Old Nov 27, 2012 | 08:52 AM
Archion's Avatar
Archion
Veteran: Marine Corps
And when you put them back in, you will want to adjust the suspension using the factory specifications. There was a thread on it a while back where I posted all the info. You will keep eating boots if you keep the keys cranked all the way up.
edit:
Here is the thread with the info.
https://www.ford-trucks.com/forums/1...ot-issues.html
Old Nov 27, 2012 | 12:29 PM
coolguy1419
I agree if you have them cranked up all the way you are going to eat ball joints and cv boots. I had this problem on my truck I previously had. And when I lowered it back down but not all the way everything was fine. Plus it rode a whole lot better the front suspension could actually work it wasnt so tight. Good luck with whatever you choose to do.
Old Nov 28, 2012 | 06:15 AM
BFTUFF's Avatar
BFTUFF
It's cheaper in the long run to just replace the axle shaft assembly/s and some new knuckle and diff. seals about $60.00 a side and your labor.
Old Nov 28, 2012 | 08:46 AM
Archion's Avatar
Archion
Be careful with that, the inner joints on a lot of the cheaper replacement axles are three-axis/Tripod units and are COMPLETELY incompatible with a lift. It needs to have the OE style six-axis/Rzeppa style joint. Found that out the hard way too...
It is not hard at all to do a boot replacement. If you have the skills to pull the axle, you have the skills to swap the boot. Just don't put a split boot on it.
Bennyboy2002
Jun 15, 2010 07:51 PM
mattdmason
13
Dec 31, 2009 02:51 PM
gearhead351
Jan 16, 2009 04:42 PM
Apache
Mar 3, 2008 02:11 PM
