tranny swap?
Old May 22, 2003 | 09:24 PM
flyvee1's Avatar
flyvee1
tranny swap?
hi ,im kind of curious if i can take two c-6 trannys (1977)one 4wd and one 2wd,and swap the tailshaft housing from the bad 4wd tranny to the good 2wd trans,,or do i have to have all the guts swapped,,anyone tried or done this before? thanks alot ,tom
Old May 22, 2003 | 10:28 PM
steve83's Avatar
steve83
tranny swap?
Just the tailshaft & extension.
Old May 24, 2003 | 11:03 AM
flyvee1's Avatar
flyvee1
tranny swap?
tailshaft & extension can be changed or cant?extension meaning the actuall input shaft?
Old May 24, 2003 | 05:02 PM
ecarter50's Avatar
ecarter50
tranny swap?
Yes you can change the tailhousing and output shaft but the trans has to be totaly disassembled to do so.
Old May 24, 2003 | 09:09 PM
steve83's Avatar
steve83
tranny swap?
"Extension" means "transmission housing extension", i.e., the back end that bolts on to the main section. The output ("tail") shaft is inside it. Most '80-96 Ford truck transmissions can be converted from 2 to 4WD or back by changing these 2 parts, but as ecarter50 said, it often requires extensive disassembly.
Old Mar 18, 2004 | 12:30 AM
duback66's Avatar
duback66
Does the same hold true for a t-18? Can you just change the adaptor?
