Shuddering during acceleration
Old Nov 25, 2012 | 03:10 AM
Paradokkusu's Avatar
Paradokkusu
I have a'92 Ford F150 with a 5.0 liter and a 5-speed manual transmission. I noticed here recently that it shudders or shakes noticeably when accelerating from a dead stand still AND while rolling. It also idles and runs on the highway real rough; like it's not running on all eight.
Any suggestions on what I should do to narrow down the wide range of problems it *could* be greatfully appreciated.
Old Nov 25, 2012 | 10:01 AM
Weberman3's Avatar
Weberman3
I have the same as you do, except AOD. I also had to same problem. When was the last time you changed the sparkplugs?
The first thing I did was take the air intake tube off and clean the carbon off. It helped very little, but it was still notable cause it was that bad. Then I took off the distributor cap and the contacts were pretty gone. I replaced that. I just replaced that alone cause it was getting dark and didn't have time to do the rest for awhile. That helped significantly. But I could still feel it. I changed plugs and wires. the plugs were at like 70.. I think they are supposed to be 53. If you still have the sticker under your hood with the vacuum lines, it should be on there. I think thats why I got that number from. I changed the wires cause they were the original wires from the factory. Said 1992 and Ford on em.. Also one boot was cracked and l broke one. After all this.. It now runs smooth.. My idle was also high cause I guess my dad kept turning it up higher and higher when the plugs wore and made it go lower.
Old Nov 25, 2012 | 10:04 AM
DIYiT's Avatar
DIYiT
Is the shuddering speed dependent? RPM dependent?
If it's speed, but not RPM dependent, it sounds like you may be in need of new U-joints, tire balancing, or something similar after the transmission.
If it's RPM dependent, the problem is before the transmission and could be a rough running motor or a problem with the transmission itself.
Old Nov 26, 2012 | 09:31 AM
Paradokkusu
I did check spark plug number 1 in number 8 in the gap reading was between .07 and .06 so I do need to change those. I plan on checking the distributor and rotor next thanks for the input.
Old Nov 26, 2012 | 09:32 AM
Paradokkusu
I believe the problem is most definitely rpm dependent it can be idling without being in gear and still shutter real bad. I plan on doing a ignition tune up as soon as I can to see if that solves the problem. Thank you for the ideas.
Old Nov 26, 2012 | 09:35 AM
Paradokkusu
I've also change 2 out of 3 of the u-joints. the last u joint that needs to be replaced is near the transmission so that might be the problem as well.
Old Nov 26, 2012 | 09:50 AM
Conanski's Avatar
Conanski
If it shudders at idle you could have a broken or bent valve so do a compression check on all cylinders.
86stepsideF150
64
May 17, 2009 04:44 PM
Dr. Dirt
May 26, 2008 08:06 PM
79f100six
Jun 30, 2007 10:51 AM
TXDod65
17
Jan 28, 2005 03:57 PM
