There are two lights on my 97 F150 on the instrument panel that dont illuminate. I replaced the bulbs with new ones several times and also the sockets but still not working. The lights are the 2 small T5 illumination bulbs just close to the board conector and lower than the turn signal bulbs. I tested the bulbs and they are good.Al lthe other lights are working fine.
Also under the dash there are 2 big gray elctriclal conectors that are not pluged and i dont find where to plug them.One is attached next to the OBD connector and the other the wires come behind the fuse box.
The truck is running fine
Im new here so unable to post pictures.
Thanks.
Temy
