Sponsored by: Real Truck
electrical problems...
Old Nov 24, 2012 | 07:29 PM
NANNERPIEZ's Avatar
NANNERPIEZ
Unhappy electrical problems...
hey everyone! Im new to the forum. I just purchased a 1999 ford F250 superduty super cab lariat. here is my list of problems so far with it. The display on the roof that says the mileage and what ever else its supposed to say doesnt come on, cab light does not turn on when the door opens or when the dimmer switch is turned on, the screen on the radio doesnt come on either. The illumination light on the inside that lights up the switches works but not the display that says the time or the station. those are the only problems i have found so far. If anyone knows how to get these things to turn on It would be great if you could give some advice to a new ford truck owner. I did check the fuses and I am missing the fuse map, there are no blown fuses so thats what brought me to the forum. looking forward to any help this wonderful forum could give me.
Old Nov 24, 2012 | 07:48 PM
SC_Hoaty's Avatar
SC_Hoaty
The fuse map is in the owner's manual. If you need another copy, you can download it here:
http://www.motorcraftservice.com/pub.../99f23og4e.pdf
Old Nov 24, 2012 | 07:50 PM
SC_Hoaty's Avatar
SC_Hoaty
In addition to the fuses, note Relay 1 is labeled Interior Lamp Relay
Old Nov 24, 2012 | 08:00 PM
NANNERPIEZ's Avatar
NANNERPIEZ
thanks man. today i downloaded that same link and was looking at the map and the fuses and none were missing and none were blown. I may have to give it another look over. thanks again for the info.
Old Nov 24, 2012 | 08:03 PM
SC_Hoaty's Avatar
SC_Hoaty
Hope that helps - if not on this problem, then on a future one.
Old Nov 24, 2012 | 08:11 PM
NANNERPIEZ's Avatar
NANNERPIEZ
oh yeah the thing on the roof i was talking about that doesnt come on is the trip planner.
Old Nov 24, 2012 | 08:19 PM
SC_Hoaty's Avatar
SC_Hoaty
I understand some folks call it the Lie-O-Meter.
Old Nov 25, 2012 | 02:41 AM
Yahiko's Avatar
Yahiko
How did you check the fuses? The look at it is not the best way.
Get a DMM and check the resistance it should show as a short
ie 0 ohms. Then put on lead on a ground point and on voltage
you should get 12V on one side of the fuse socket the other side should
not have any voltage but may have some do to the way Ford does some things.
Also look up under the dash behind the fuse panel and look to see if it has gotten
wet and/or any fuzzy green stuff on the wire terminals.
Sean
Old Dec 17, 2012 | 10:56 AM
KCChiefs1957's Avatar
KCChiefs1957
F250 1999 Diesel - Electrical Problems
Couldn't find where to start a new topic / question so posting on to this thread.
Posting for husband:
1999 F250 7.3 Diesel having electrical issues this am. Wouldn't start. Truck was jumped, started. Going down the road, windshield wipers came on for no reason, no spedometer, no gas gauge, the overdrive button on the steering column started flashing. Stopped at wife's work and left truck running while going inside. Truck died while inside. Now it won't start at all. Taking off alternator to have it tested. Anybody know what the electrical issued might be if alternator test ok?
Old Dec 17, 2012 | 11:04 AM
SC_Hoaty's Avatar
SC_Hoaty
Your question will get poor exposure here.
Here is what the button to start a new thread looks like:
Flargen
May 17, 2016 03:08 PM
chrs2ca
May 14, 2016 03:30 AM
fordmustangfan67
Electrical Systems/Wiring
Apr 29, 2016 06:49 AM
DocMilenko
Jun 17, 2004 10:29 PM
SnubNose
Aug 7, 2003 08:46 AM
