Sponsored by: Real Truck
08-Up Tail Gate
Old Nov 23, 2012 | 05:03 PM
Sarge261's Avatar
Sarge261
08-Up Tail Gate
I finally got my hands on a 11 tail gate. Dropped it off to the body shop for paint today. So the question is, without sifting through a ton of posts what are the part numbers I need to install this on my truck. I know there is a latch that I need to make it work but nor sure of a part number.
Thanks,
Sarge
Old Nov 23, 2012 | 09:19 PM
SuperDutyScaler's Avatar
SuperDutyScaler
im not 100% but i think the hinges need to be changed also?
Old Nov 24, 2012 | 05:52 AM
scraprat's Avatar
scraprat
Top Answer: 5
Take your hinges off the old tailgate and swap them, your good to go. Also put a pipe clamp on the bottom passenger side hinge and that will prevent the scum from just lifting the door off.
Old Nov 24, 2012 | 06:50 PM
BobbyDiesel71's Avatar
BobbyDiesel71
yes, you def need a driver side hinge(pivot) but buy the passenger side too
$12.00 each
Old Nov 26, 2012 | 07:32 AM
Sarge261's Avatar
Sarge261
So If I swap the hinges do I still need to buy them? I thought it was only the D/S that needed to be replaced?
The gate is at the body shop so I will have to wait to get it back to have a look.
Old Nov 26, 2012 | 06:37 PM
Fordfanatic4life's Avatar
Fordfanatic4life
it is the drivers side that only needs to be replaced...
and its the part that bolts to the box not the tailgate, cuz well that parts welded on anyways, hahaah
Old Nov 27, 2012 | 08:02 AM
Sarge261's Avatar
Sarge261
Anyone have a part number real quick, and I guess while Im at it what would I need to put an 08-up rear bumper on, Do I just need the bumper and pad or all the supports as well.
I hate body work, mechanical no problems but body work I hate.
Thanks,
Sarge
Old Nov 27, 2012 | 11:02 AM
RUNVS's Avatar
RUNVS
No idea on part number for the hinge pivot, but you are right, only the drivers' side needs replaced.
I recommend the hose clamp as well for the passenger side. Of course it is not 100% foolproof, but these tailgates can be removed in 30 seconds. Anything you can do to slow them down is worth it.
You could get the clamp from McGard (amazon sells them) which has a special head on it so a regular screwdriver or nutdriver won't work.
No...you do not need a 2008+ bumper. Yes, you can swap one in but not necessary.
Old Nov 27, 2012 | 11:12 AM
Sarge261's Avatar
Sarge261
I know I dont need 1 but may as well do it as mine is a little rusty, just wondering if I need to replace all the supports or just unbolt the chrom bumper itself and swap in an 08-up or do I need all the supports behind the bumper to make it work.
Sarge
Old Nov 27, 2012 | 06:28 PM
Fordfanatic4life
you can swap it on using the brackets the bumper comes with, but your spare tire access rod wont lineup.
minor issue depending on if you actualy use ur spare tire i guess.
nassi
1978 - 1996 Big Bronco
Dec 16, 2018 06:45 PM
firstrider
Ford Truck Parts for Sale
Dec 5, 2016 12:45 AM
Eric1967
Sep 14, 2014 09:35 AM
kpmalone
Jun 30, 2010 05:03 PM
mtflat
Feb 10, 2005 08:45 PM
