Drivers Side Air Vent...
Old Nov 23, 2012 | 08:45 AM
jpcole9702's Avatar
jpcole9702
So as I was driving my truck from Alabama to Wisconsin last week, and then to Kansas this week. It became rather cold inside the truck. First issue was that my heater was very non-existant as I am running an 160' thermostat. Second issue is that my drivers side air vent is full of leaves and you cannot close it. My question: Does anyone have any tips for taking the vent cover off, as the parking break seems to cover the upper screw and looks to make it very difficult to remove. Also, is there anywhere to get a replacement vent cover. Mine is cracked and the handle of the vent itself is broken off. Ill have to post my travel story a little later.. it was a great trip with only a few issues...
Old Nov 23, 2012 | 02:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by jpcole9702
So as I was driving my truck from Alabama to Wisconsin last week, and then to Kansas this week. It became rather cold inside the truck. First issue was that my heater was very non-existant as I am running an 160' thermostat. Second issue is that my drivers side air vent is full of leaves and you cannot close it. My question: Does anyone have any tips for taking the vent cover off, as the parking brake seems to cover the upper screw and looks to make it very difficult to remove.
C8TZ-8102105-C1A (replaced: C8TZ-8102105-C2D -C2S; C7TZ-8102105-C1D -C1R -C1S -C1T) .. Left Air Vent-Paint to Match / Obsolete
1967/71 F100/750 / 1972 F100/750 before serial number P20,001.
No Ford Dealer or obsolete parts vendor has C8TZ-8102105-C1A
C8TZ-8102105-C2S =
JST AUTOMOTIVE in Lebanon TN has 1 = 615-443-3086.
C7TZ-8102105-C1T =
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
No heat? Don't blame the 160 t/stat. I used the same t/stat in my '65 F100, heater worked fine for over 30 years.
The 1965/72 cable controlled heater water valve (C3UZ-18495-A) is spliced into the inlet-to-heater-core heater hose.
The little charmer is notorious for getting stuck in the closed or partially closed position. The good news is, it's available from Ford.
MSRP: $46.16 / FTE sponsor tousleyfordparts.com price: $25.39 / Tousley Ford ~ White Bear Lake MN
Old Nov 23, 2012 | 06:25 PM
HIO Silver's Avatar
HIO Silver
So as I was driving my truck from Alabama to Wisconsin last week, and then to Kansas this week. It became rather cold inside the truck. First issue was that my heater was very non-existant as I am running an 160' thermostat. Second issue is that my drivers side air vent is full of leaves and you cannot close it. My question: Does anyone have any tips for taking the vent cover off, as the parking brake seems to cover the upper screw and looks to make it very difficult to remove. Also, is there anywhere to get a replacement vent cover. Mine is cracked and the handle of the vent itself is broken off. Ill have to post my travel story a little later.. it was a great trip with only a few issues...
I don't think it is that hard to remove the parking brake. Release the tension, and then loosen four nuts on the firewall and like one or two bolts under the dash and swing it out of the way. C'mon. Give it the ol' college try.
IIRC, the vent gasket is the only repro piece.. otherwise, make a salvage yard trip unless ya wanna seek out the OEM pieces cited above. The vent assembly doesn't seem to be a highly sought after part given what I've noticed while window shopping at the man-mall.
Old Nov 23, 2012 | 06:26 PM
MIKES 68 F100's Avatar
MIKES 68 F100
I drilled a 1/2 hole in the top back corner of my bracket for access to the screw other ones i got with a offset screwdriver .
check ebay for the the vent i found one for $7.00 to put on my passengers side till i get my classic auto air .
Old Nov 23, 2012 | 06:31 PM
bmuhlbach's Avatar
bmuhlbach
There are 2 bolts under the hood and one under the dash and it will swing out of the way.The vent is the same or simalier to up to 79 so gives you more options.I bought new gasket kit for mine from Dennis Carpenter and redone mine.
Old Nov 23, 2012 | 06:54 PM
NumberDummy
Originally Posted by bmuhlbach
The vent is the same or similar to up to 79 so gives you more options.
The vent is not the same for 1972's from serial number P20,001, not the same for 1973/79.
Later vent may fit, but it's not the same as 1967/71, some 1972's.
Took me 30 minutes to look up the part number, find out what it replaced, search for the obsolete parts, type the applications and the sources in post 2.
Then you come along (without a part catalog) and say different, probably in less than 60 seconds.
Old Nov 24, 2012 | 04:02 PM
MIKES 68 F100
73-79 vents have a notch in the top to fit around the dash ,other wise the same .
one i got on ebay was 73-79
Old Nov 24, 2012 | 04:04 PM
bmuhlbach's Avatar
bmuhlbach
sorry You are right they aren't the same I mis typed that .I think the 73-79 will bolt in the same holes as the old one.
Old Nov 24, 2012 | 04:17 PM
MIKES 68 F100
yes exact same holes and looks .
Old Nov 24, 2012 | 08:38 PM
williamwilliam's Avatar
williamwilliam
yes sir.
Old Nov 25, 2012 | 09:47 AM
MIKES 68 F100
Here's a pic of the 73- one notice the notch in corner ,
Old Nov 25, 2012 | 09:49 AM
jpcole9702's Avatar
jpcole9702
Looks great.. Got one to spare?
Old Nov 25, 2012 | 09:54 AM
MIKES 68 F100
i will once i get my classic auto air system , for now it's keeping the cold air out my cab.
ktmduke640
Oct 1, 2014 05:00 PM
DRRXR
Texas Chapter
114
Jan 18, 2012 11:55 AM
664x4drvr
Apr 18, 2010 10:55 AM
6CylBill
35
Mar 7, 2010 08:15 PM
msayc42
Paint & Bodywork
Jul 25, 2006 08:43 PM
