Sponsored by: Real Truck
Need advise update
Old Nov 22, 2012 | 10:53 AM
docsouce's Avatar
docsouce
Need advise update
Hi Folks
I've been able to search the threads here and I think I have my needs figured out.
I want to pick up a slide camper for my 2008 F250 4x4. It's a 5.4 auto with the factory towing kit. (has the tow/haul button on the shifter.) 3.73 limited slip rear.
I figure I need to add a rear sway bar kit, probably Hellwig, a set or air bags, Air lift or Firestone, and maybe tie in an onboard compressor to one of the aux. switches. So far so good.
With the air bags, do I still need to add a helper spring to the rear leafs?
Any other suggestions?
Dave
Old Nov 22, 2012 | 01:11 PM
2000silverbullet's Avatar
2000silverbullet
You'll probably be over the GVWR of your truck, but I wouldn't expect anyone to hassle you over it. Make sure your tires are E rated and aired up.
I'd get the air bags installed with the camper sitting on your truck, then decide if you need helper springs. I doubt you will, you'd be surprised what those bags are capable of handling.
Shovelheadrob
Mar 16, 2019 12:34 PM
PROSTOCK
All Things Towing
23
Apr 28, 2014 05:55 PM
73 fourxfour
Nov 25, 2011 07:12 PM
Ford Truck Racer
Apr 16, 2007 07:43 AM
Gary E
Jun 11, 2006 11:14 PM
