Cylinder questions
Old Nov 22, 2012 | 09:20 AM
Jason6969's Avatar
Jason6969
Cylinder questions
[/IMG]Anyone know what would cause this? 300 six 1989, 130,000 pulled apart for head gasket issues. no scratches felt when you run your fingernail across it. carbon? only visible in a couple cylinders this is the worst one.
Thanks,
Ross
Old Nov 22, 2012 | 09:41 AM
68cabby's Avatar
68cabby
Check your rings. They might not b scratches, but domthin may be up with your rings.
Old Nov 25, 2012 | 11:42 AM
4x4 Bart's Avatar
4x4 Bart
Running without EGR working = high cyl temps and ring damage ???
Old Nov 25, 2012 | 07:39 PM
Harte3's Avatar
Harte3
That might be caused by piston slap. Do a Google search on piston slap and cylinder scuffing.
Old Nov 25, 2012 | 09:16 PM
fordman75's Avatar
fordman75
Could also be a cracked piston skirt. Which isn't to uncommon with a stock piston in a 300.
Old Nov 26, 2012 | 08:35 AM
Fordownsall's Avatar
Fordownsall
Thanks,
Ross
With that being said, and the way it looks I wouldn't call it metal-to-metal contact. If he had scuffed or scored pistons, rings, or cyl. walls he would have excess oil bypassing rings and getting into the comb. chamber.
It looks like light up and down scuffing, normal. If your pistons have markings you could make sure they are faced in the right direction and in correct relationship with the connecting rods.
If you are worried about it, take some measurements? Check for out-of-roundness and/or taper. If it checks out good keep on truckin
Old Nov 28, 2012 | 03:00 PM
4x4 Bart's Avatar
4x4 Bart
O.K. guys look at how high up in the cyl the marks are. It cant' be the piston skirt.
It's not the top of the piston either because the top of the piston extends above the marks.
It's the rings.
Old Nov 28, 2012 | 05:46 PM
Jason6969's Avatar
Jason6969
Thanks for all of the replies! I found out the head was also cracked in the #6 exhaust valve seat; so i have some scrap, I have another 300 I can install in the truck. (I found out it had been run hot on occasion)
Thanks again!
Ross
pineconeford
19
Apr 19, 2016 07:33 AM
BroncoBilt
Jan 16, 2015 01:50 PM
joecali
3.8 & 4.2L V6
Dec 17, 2007 03:28 AM
Remy
Mar 9, 2000 08:46 AM
oleblue70
Jan 16, 2000 08:46 PM
