302 Engine noise
Old Nov 21, 2012 | 09:11 PM
Chuck-AZ's Avatar
Chuck-AZ
302 Engine noise
Has anyone experience with E6TE high swirl cylinder heads? Can they cause a detonation (ping) at idle. Timing at idle (680 RPM) is 10 deg and will go to 30 deg at higher RPM. Engine temp 190 deg. The engine has a diesel sound at 680 RPM and is gone at 800 RPM The ECC IV system is working properly.
The engine is a 1987 port injected 302, with no modifications.
Any ideas?
Old Nov 22, 2012 | 09:09 AM
baddad457's Avatar
baddad457
You might have an injector or two that are plugged, allowing a lean condition to exist at a lower rpm. Or could have one that's blown the tip, alllowing it to flood the cylinder. The E6 heads are more sensitive to timing according to Ford though and get by on less timing.
Old Nov 22, 2012 | 10:08 PM
Chuck-AZ's Avatar
Chuck-AZ
Thanks for the information on the not so common E6TE cylinder heads. I will play with the timing and look at the spark plugs for signs of injector problems. I plan to try some higher octane fuel to see if it makes a difference. I think it's pistons, but it doesn't sound like pistons.
Thanks
Old Nov 23, 2012 | 08:53 AM
Conanski's Avatar
Conanski
I had a set of those on a motor and found it was less detonation prone than the standard heads.. I could throw all kinds of timing advance at it.
What is your oil pressure?
Old Nov 23, 2012 | 08:59 AM
baddad457's Avatar
baddad457
Thanks
Are they E6TE, or E6SE heads ? Look at the lower front corner of the passenger side head, next to the valve cover. There you will find a letter cast. If that letter is an "S", then those are E6SE heads, which are the high swirl, fast burn heads. If there's a "T" cast there, those are the std truck head, which are not the high swirl fast burn heads.
Old Nov 24, 2012 | 08:04 PM
Chuck-AZ's Avatar
Chuck-AZ
Haven't found the S or T yet, is it on the intake side or exhaust). But, when I had the heads off they were the same as this link http: .diyporting.com/E6TE.html (not sure if I can post a link, so this should do) The engine is from a 1987 T Bird. Oil pressure is 35 hot and 45 cold. I plan to put about 300 miles on the engine next week end and should know more after the trip. If I tell you this engine is not in a truck, will I be banished for the forum ? I hope not. You guys are good.
Thanks
Old Nov 25, 2012 | 09:47 AM
baddad457's Avatar
baddad457
The letter is cast outside of the valve cover, in the lower front corner of the valve cover. The same letter will appear in the lower rear of the driver's side head. 87 T-Bird should have E6SE heads if I recall. These have an "S" in that location.
BeauF0RD
Jul 24, 2017 09:11 PM
ddeflyer
20
Feb 13, 2015 08:29 AM
Bro107
Nov 6, 2007 02:13 PM
79 E350 rescue
Nov 3, 2005 12:58 AM
sparkie182
Sep 13, 2004 09:20 PM
