Advance Timing.
Old Nov 2, 2007 | 01:15 AM
Bro107's Avatar
Bro107
Advance Timing.
I'm running a single pattern cam(roller) lift .498 adv. duration 282 with shaved H.O. heads. My timing is set at 10*and I'm wondering if I should run it at 12*and how many RPM's at idle? My idle is set at 700.
80 F150
Old Nov 2, 2007 | 01:22 AM
Bro107's Avatar
Bro107
By the way the engine is a 302 Mustang GT with a 600 cfm Edelbrock and performer air gap intake.
80 F150
Old Nov 2, 2007 | 04:12 AM
HemiEater's Avatar
HemiEater
run as much timing as you can.......when it startes to ping just back it off a little....
Old Nov 2, 2007 | 05:52 PM
baddad457's Avatar
baddad457
Ditto, run as much timing as the fuel you're using will tolerate. Sounds like you've got an E303 cam.
Old Nov 3, 2007 | 11:34 AM
Mr. M's Avatar
Mr. M
Depending on how much your heads were worked... you should be able to run 18* or more on premium fuel and 13-15* on 87 octane.
Like hemi said, advance it until you hear it ping, and then retard it a little.
Old Nov 5, 2007 | 10:15 AM
clgreer's Avatar
clgreer
ive always been curious what exactly a "ping" sounded like. ive tried to do this on my 302, and never really heard a ping. of course ive only advanced it to about 12-14 myself..
Old Nov 5, 2007 | 04:44 PM
baddad457's Avatar
baddad457
Pinging is also refered to as "valve clatter", this is usually heard in accelleration. When I first fired off my 331, the tank was full of 87 octane, in that instance, it didn't ping, it was more like gravel being crushed in the cylinders.
Old Nov 6, 2007 | 01:38 PM
Bro107's Avatar
Bro107
What about the idle what should it be set at?
80 F150
Old Nov 6, 2007 | 01:50 PM
Bro107's Avatar
Bro107
Baddad ,the cam is Powermax 2040 (Crane Cams). It seems to pull strong.
MR.M Nice truck!!!
80 F150
Old Nov 6, 2007 | 02:13 PM
Mr. M's Avatar
Mr. M
Originally Posted by Bro107
MR.M Nice truck!!!
80 F150
Thanks!
