I have a 99 F250 2 door. The power window switch (i think typical of Ford electrics) has failed. The contacts burn up, I have taken apart and cleaned the contacts several times, but it will only last a few weeks before carbon/black junk from arcing builds up again.
Local Ford dealer says this is a problem, always keeps a few of the switches in stock. Also says that the replacement is no different than the orig switch, and that it will last about a year or two before it fails.
Anybody found a better cure for this problem? I'm thinking that maybe the switch contacts are not making a real tight contact when flipped in the up position, making slight arc under load. Is anybody making an aftermarket redesign switch for this?
If you want to reduce the AMPS accross the switch contacts, you can simply put a radio shack relay in line to the window motor and use the switch (lower current) to activate the relay.
Crimp the contacts so they make a tighter fit and use NOLOX paste or dielectric grease to stop the loose fit arcing problem. Nolox is a paste put on alumnium and other connections by electricians because aluminum is notorious for working loose and then arcing till it blows.
Window switches burning up has not been a problem that I have heard of... and this is the place to hear about problems! If you want to fix it, quit buying switches and maybe change the window "motor". If it happens to each switch you put in, something in the line is drawing too much current.
electronics tech friend measured draw on window motor, it was same as passenger window, and the same in his 250.
The contacts in the switch look a lot like the points in an old points-type distributor, small metal contact pads on flexible brass springy things. There are five contact points in the driver side switch.
When it didn't work this AM, I pulled out the switch, and with contacts exposed, plugged the leads back in, then used pen to mash down the proper contacts that the levers push when you rock the toggle from up to down. Window worked fine....so it seems that the problem is clearance (too much) between the plastic rocker part of the control, and the electrical contacts portion of the switch. Since the contact points aren't mashed together much -- or at all, arcing is occuring.
Now I just have to figure out how much, and how to, add a little more "throw" to the mechanical portion of the switch control
DON'T CRIMP THEM!! Go get some of that electrical jelly crap and try that! I might even save your old switch. You can get it from an electrical supply house.
