if you don't want it when you cut it out send it my way i would find something to do with it I'm sure. it just looks too cool and is from JCPenny which just adds to the interesting/cool factor. ill pay postage.
I get the cool of the J C Penny stuff, I have a bunch of my grandpas J C Penny tools including my favorite ratchet, it has a massive rubber grip on the handle.
At the moment I just want to get the truck running before my shoulder heals so I can go back to work.
If I tear it out I will pm you. (I have no idea why this started to print in italics.)
I was wondering if it was maybe a 70's corvette, as they had tilt/telescopic(before I even saw the pictures). After seeing the pics, it's not Corvette. Looks more "60's ish" then anything newer? I wonder if there is a badge under the Ford oval in the horn button?
Im wondering the same thing. I thought it was a vette too until I saw the transmission indicators.....did any vettes come with a column shifter??? I know most Ive seen are in the floor. Maybe the PO can look for some part numbers on the column when he takes it out and post those on here and maybe someone can find out what it is. I dont think its a Ford, maybe 60-70's GM?????
Telescopic steering wheel on 1966/70's Cadillac's, other GM cars. Move the emblem, wheel comes straight out of the column, column itself doesn't telescope.
And that appears to be what this wheel does.
Only 'Vette I've owned was a '63 split window, A/T shift lever on the floor, radio mounted sideways in center stack. Took some getting used to.
That steering wheel sure as heck piqued my curiosity so I did a search last night but to no avail. The closest on wheel appearance/style I found is a 63 or 64 Lincoln Continental.
50s wheels seemed to have more plastic whereas this appears sleek and thin. Then I thought maybe it came from a truck but tucks back then were more utilitarian. Again, contrary to its design.
My wild azz guess is an early 60s Mercury, Dodge, or Chrysler ...before 67 cuz (IIRC) that year the DOT required padded horn bars (EDIT: Commercial vehicles like trucks exempted).
.... the mystery continues.
Reason: Clarification
That's an interesting retrofit - I mean the telescoping and tilting column. If ya could and if ya would, maybe post up some pics on how the PO did it. I mean, Caddys sometimes show up in the yards. It'd be dang cheaper using JY parts compared to an Ididit column at $450.
... and I know that some FTE'ers with auto trannys might be interested in the swap instead of using a late Dentside column.
I will snap some pics tomorrow, Off the top of my head I would say it is mounted just like the stock column but I don't know how they mounted it to the steering box.
I knew about the Cadillac's cuz a friend had a 1966 Cadillac Fleetwood Brougham with the tilt/telescopic steering wheel. No FoMoCo vehicle in the 1960's had a telescopic wheel that I'm aware of.
1965 was the first year for the tilt wheel feature. Optional in full sized Ford/Merc's and Lincoln's.
1963/64 Galaxie 500/XL/full sized Merc's with A/T were available with the optional "swing-away" steering column. Put the car in park, the column could be swung to the right, making it EZ to exit the vehicle.
