Dear God Hellwig
Old Nov 18, 2012 | 01:52 PM
sammie0126's Avatar
sammie0126
Welcome John. Glad you got it in, not sure what I have left been awhile. But if you are missing one I'm sure you will know and Tim's post should help.
Old Nov 18, 2012 | 02:07 PM
timf150's Avatar
timf150
Here is how one member used up some of the extra washers.
And he drilled new holes so that his sway bar was more level, here is his thread if you want to check it out.
https://www.ford-trucks.com/forums/1...e-maybe-2.html
Tim M
Old Nov 19, 2012 | 09:11 AM
swheeler's Avatar
swheeler
Looks like you are all set but here is a link to an album I created with pics from my install.
2003 Ford Excursion 4x4 - Hellwig rear anti sway bar ins
Old Nov 19, 2012 | 09:51 AM
Apocalypse's Avatar
Apocalypse
My favorite quotes from the hellwig site:
Average Install Time: 1 to 2 hours
Fast, Easy "Bolt-On" installation
Includes all required mounting hardware
Also, on a completely stock v8 2wd how much difference should this make?
Old Nov 19, 2012 | 10:01 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Makes a huge difference in how it drives and how it tows. You need one if you don't have one!
Old Nov 19, 2012 | 10:15 AM
Jigger2020's Avatar
Jigger2020
Great info there Wheeler & Mike, well done Wheeler
Old Nov 19, 2012 | 10:23 AM
timf150's Avatar
timf150
swheeler...those end links look different from the ones that came as part of my setup. Is that a newer type they are selling?
TimM
Old Nov 19, 2012 | 01:07 PM
ExxWhy's Avatar
ExxWhy
Originally Posted by jspence105
All installed. Thanks so much sammie I wish I had posted when I first started to get annoyed I ended taking everything apart again and putting the parts where they seemed like they should go. I still have 4 nuts and 2 washers, but I'll call them extra parts.
This is what it looks like now.
The 4 extra nuts you'll want to use to double nut the brackets that go around the axle. You can see how they go in Timf150's pic. Not so sure on the extra washers, but seems like I had extra parts when I installed mine as well.
Every "how to" I've ever seen on here always starts with "after I threw away the horrible instructions, it went well."
Old Nov 19, 2012 | 01:55 PM
golfmedik's Avatar
golfmedik
Now, with it installed, go out down the road around 45 mph or so and do a 'panic stop' and watch how the truck reacts. Her rear will stay down and very level, much more controllable. The best results are in the ones you have to do in a curve(I don't promote practicing that type). The rear will stay under the truck keeping more weight on the rear tires. Very much worth the money!
Old Nov 19, 2012 | 03:13 PM
jspence105's Avatar
jspence105
I'm glad I installed it, I'm just shocked at how confusing the instructions were. one ot two simple diagrams would clear it up making it a breeze to install. I spent most of my time installing and then uninstalling repeatedly thinking I had made mistakes. The simple fix for this is to make all the washers the same, this thick/thin is nuts and the ID difference of .032 is insignificant.
Old Nov 20, 2012 | 01:15 AM
jh818's Avatar
jh818
Check out some of my photos in my album. I tried taking step by step photos until my hands got too greasy to snap any more photos. Grease from putting grease on the bushings.
Old Nov 20, 2012 | 07:29 AM
$$$=SPEED's Avatar
$$$=SPEED
Love how everyone helps on this site! Here is a dumb question from me again. If I do not tow what advantage or improvement does the hellwig give the X?
I am about to put a suspension lift on my X and keep reading here about the hellwig. Thanks
Mike
Old Nov 20, 2012 | 08:09 AM
  #28
jh818's Avatar
jh818
Mike
It improves handling on curves. Reduces body roll on turns.
Old Nov 20, 2012 | 08:23 AM
  #29
$$$=SPEED's Avatar
$$$=SPEED
A must then with a lifted truck I would assume? Thanks for your prompt reply
Old Nov 20, 2012 | 09:17 AM
  #30
swheeler's Avatar
swheeler
TimM
I think mine is an older version. I did mine a long time ago. If I had to guess I'd say it was 2005 ish.
