Radiator Help!
Old Nov 17, 2012 | 04:04 PM
F-150_SuperBeast's Avatar
F-150_SuperBeast
Radiator Help!
Hey Guys,
I've got a 1993 F-150 4.9 I6 and I just pulled my radiator out because it was starting to leak in a few spots. I've been all over town looking at radiators to buy and they all are different from the one I have.
My radiator only has the two large tubings on it, however the new ones have two small female fittings on the left side (under the fill cap). I assume these are for transmission cooler lines, but I don't have those to fit there. Am I supposed to plug these up, or am i not understanding something?
Thanks for your help
Old Nov 17, 2012 | 04:23 PM
Spktyr's Avatar
Spktyr
At least one of those would be for the overflow tank, I'd think.
Old Nov 17, 2012 | 06:05 PM
Volvo92906's Avatar
Volvo92906
I misread and was assuming you were talking about the overflow fittings...
Yes... Those are for the transmission oil lines. They will be fine if you just cap them to keep dirt and crud from getting in..
Old Nov 17, 2012 | 08:43 PM
alabamabuddog's Avatar
alabamabuddog
Those are transmission line inlet and outlet. You shouldnt have to do anything to them. The only line you need to run to the over flow comes out right under the cap.
Old Nov 17, 2012 | 08:46 PM
Volvo92906's Avatar
Volvo92906
Delete.....
Old Nov 17, 2012 | 10:18 PM
2002 F350V10's Avatar
2002 F350V10
Replacements come with the trans cooler inside the one tank. If you dont need them as your truck must be stick, just plug them as it isnt needed in your instance. They sell inverted flare plugs at aute part stores , or they might be included with the replacement radiator.
Old Nov 18, 2012 | 06:13 AM
bdelmar2's Avatar
bdelmar2
I think all the radiator manufacturers have gone to making the radiators fit either autos or manuals. Parts places and even the specific radiator place around here don't even ask which kind it is anymore. Must be cheaper to make them fit both rather than deal with having to distinguish between them.
Old Nov 18, 2012 | 06:18 AM
Archion's Avatar
Archion
Veteran: Marine Corps
You do not have to plug them at all, just leave them alone, anti-freeze does not flow through an automatic transmission. What I find amazing is none of the "parts people" explained that to you.
Old Dec 18, 2012 | 10:59 PM
F-150_SuperBeast
Cool, Thanks everyone for responding. I didn't get a chance to get back on after I figured it out, but i'm glad my reasoning was substantiated by knowledge! And who would've thought they would have forgotten to explain that to me
Old Dec 19, 2012 | 11:49 AM
dixie460's Avatar
dixie460
Right, it's simply a water/oil heat exchanger in the side tank. But I would plug them, you don't want the internals to corrode because then you'll have a leak again.
bellinoracing
2004 - 2008 F150
52
Sep 10, 2019 11:26 PM
Bobseaweed
1983 - 2012 Ranger & B-Series
Aug 13, 2007 08:35 AM
bhebb
May 21, 2006 09:14 AM
amsuco
Oct 31, 2004 07:41 AM
bulabula
Feb 20, 2002 08:18 AM
