Sponsored by: Real Truck
12V Switched
Old Nov 16, 2012 | 12:04 PM
2012 F250 6.2's Avatar
2012 F250 6.2
12V Switched
Greetings.
Does anyone know of any trick way to get a 12V key on/off switched power source under the dashboard in a 2012 F250 short of running something to the fuse box?
I could take one of the up fitter switch wires but I dont want to use up a switch for something that I don't need to manually switch separately from the key on/off.
Anything under the footwell or steering column that is easily accessible?
Thanks for any help anyone can give.
Old Nov 16, 2012 | 12:37 PM
BigPigDaddy's Avatar
BigPigDaddy
If you have a cigarette lighter it may be ignition powered?
What are you looking to power?
Old Nov 16, 2012 | 01:03 PM
2012 F250 6.2
Thanks for the reply. Unfortunately, both of my lighter plugs are not switched. That would have been ideal.
Old Nov 16, 2012 | 01:09 PM
donovan's Avatar
donovan
uplifters
If you have uplifter switch that would work.
What you you hooking up? What is the amp draw.
If you just look for micro amps you use the power to the radio or gove box.
Old Nov 16, 2012 | 01:10 PM
2012 F250 6.2
It's very low draw. Like what a cell phone would use.
What is the power to the glove box?
Mhintlian
Mar 29, 2014 07:24 AM
snowcrash47
Mar 13, 2012 11:29 AM
mchbts
May 20, 2011 11:30 AM
Benaghetto
1983 - 2012 Ranger & B-Series
Feb 16, 2008 04:58 PM
MatthewC
1978 - 1996 Big Bronco
Dec 5, 2004 02:58 PM
