Okay, so I'm not planning on this, or saying it would work.... just a brain fart, so to speak.
1. Install centrifugal supercharger.
2. Change timing somehow so that camshaft is 1:1 with crank.
3. Install camshaft in way that intake and exhaust are open near bottom of stroke.
Anyone think it would work?
I think it might work, I doubt it would make much power, as it was never designed to run like that, but I actually think it might work.
If I ever won a million dollars, I'd buy some beer and try it
You'd have to force feed it halfway down the power stroke until about halfway up on compression. You'd blow unburned fuel out the exhaust most of the time.
Detroit Diesel has been building 2 stroke diesels for years. they make power just fine.
I used to drive one at an old job. It was the v6 supercharged/turbocharged detroit in a 1978 Kenworth. Not the fastest diesel, but it made a lot of racket and got the job done...Sometimes it would start running backwards when shutting down, bellowing black smoke from the air filter...
OK, good point, DEE troits ran just fine. But, production stopped in 1998. They also used lights or ports in the cylinder wall to fill the cylinder. Can't retrofit that to the 7.3 or any other 4 stroke.
The Toyota effort goes back a few years, and I can't find a decent link to it. They tried to use a 5 valve design with a supercharger to push air in and exhaust out via the valves, rather than ports in the cylinder. This was an effort to have a clean runner with all the advantages of a 2 stroke. This article may or may not be the right one, but a couple paragraphs down, they tell the tale. Short version: it didn't work:
