Tach Troubles
Old May 22, 2003 | 12:38 AM
HD's Avatar
HD
Question Tach Troubles
Hey there everyone,
I have a 91 F150 XLT Lariat with a 302. Its got the gauge cluster with the tach. Well, the tach jumps straight to 3500 rpm when I put the ignition in run. The only time it moves is if the engine rpm goes higher when accelerating. It'll go to about 4000 and fall back to 3500. It stays there until you shut the truck off. I used to be able to slap the dash and it would start working again, but one day I found myself wanting to punch the dash, but it would not go down, so I left it alone.
My truck has a stock everything electrical. Does it sound like Im gonna have a shorted wire in the dash or something? Any help would be greatly appreciated. Thanks in advance.
Old May 27, 2003 | 09:05 AM
HD's Avatar
HD
Tach Troubles
Tonight Im planning on tracing the wires to/from the tach and take some voltage and resistance readings. I should just be lookin for straight up 12 v dc right? I want to be sure so I dont mess up my multimeter. Im curious because it gets a signal off of the ignition coil. One more question, does anyone know around how many ohms I should expect to see if I shoot the wires from the under dash area? Thanks in advance.
Chris
Old May 27, 2003 | 09:07 AM
MustangGT221's Avatar
MustangGT221
Tach Troubles
Have you ever taken the needle off of the tach? Because if you did and didn't put it back on correctly it will do that.
Old May 27, 2003 | 09:14 AM
HD's Avatar
HD
Tach Troubles
No, Ive never messed with it. One day it just started doing it. Ive let it be weird for a good while now. Im fixin to put some after market gauges in, and I really want to get all my gauges working good. I decided not to get an aftermarket tach. Its not a dummy gauge and it works good when it does work, so I need to fix it.
Chris
Old May 27, 2003 | 06:15 PM
steve83's Avatar
steve83
Tach Troubles
1) It's mechanically able to go below 3500, as evidenced by it being down with the key off.
2) From what you said, it DOES report the correct RPM above 3500, so it works and the needle is installed correctly.
Those two facts tell me that it's an internal electronic fault, within the tach head itself. I don't think it's anywhere in the coil circuit or the tach wire. I'd start looking for a replacment tach or cluster.
Old May 28, 2003 | 03:22 AM
HD's Avatar
HD
Tach Troubles
Hmmm. Thats an interesting point. Yeah, I cant even see where the cluster would connect, let alone get to it, without it disconnected like the book says. Id rather do it all together and just end up with good gauges say, after a weekend of work. I could take the time to shoot wires then I guess. Can you get a tachometer head from the parts store? Or would I be better off to just pull a cluster out of a truck in a junkyard and hope it works? (Thats assuming that I find one with a tach cofiguration,ha!) I have one last question and then Ill shut up: Where can I get this "hook tool" that is needed to take off the wiper and headlight *****? Ive already had to replace one wiper ****, and that little thing aint cheap. Id gladly put the money toward that tool as long as I aint gotta buy more of those *****. I appreciate all the help and information. Thanks in advance.
Chris
Old May 28, 2003 | 08:04 AM
steve83's Avatar
steve83
Tach Troubles
You can bend a piece of stiff wire, or buy a set of picks at Wal-Mart or a parts store for ~$4 for 4 tools. You can see one from the WM set in this picture.
You can see how to remove the cluster here.
Parts stores don't sell the tach, and I don't think Ford does, either, but you could check. They're all over the junkyards near me, and every one I've pulled has worked (even the burnt one).
Old May 28, 2003 | 02:29 PM
HD's Avatar
HD
Tach Troubles
Man, I sure appreciate the help. Stuffs a lot clearer to me now. Im gonna go see about gettin those picks and look for a cluster at a junk yard. Unfortunately, there is only two junkyards around here in this town, and one doesnt have 87-91 body styles. I havent been to other yet. Well I guess I better leave all yall alone and get started. Hopefully I can help yall someday. Thanks again!
Chris
Old May 28, 2003 | 08:06 PM
steve83's Avatar
steve83
Tach Troubles
If you don't find it, check the classified ads here.
Old May 30, 2003 | 12:25 AM
HD's Avatar
HD
Tach Troubles
I hadnt thought of that. Ill be sure to, more than likely Ill have to! I appreciate it.
Old May 30, 2003 | 07:16 AM
Bubba Shrimp's Avatar
Bubba Shrimp
Tach Troubles
I'm with Steve on this one. You need a new tach. I saw a set of hook tools at AutoZone and my brother got a real good set (burglar quality) at Radio Shack.
Old May 30, 2003 | 08:24 PM
HD's Avatar
HD
Tach Troubles
Thanks for the heads up, bubba. Im goin tomorrow to get some at the parts store. I appreciate all the help from yall.
Chris
Aune163rd
Dec 13, 2014 08:02 AM
79boston150
May 6, 2009 06:43 PM
jdhford67
Oct 11, 2008 03:16 PM
95se5m
Mar 30, 2005 10:41 AM
leisjohn
Jul 21, 2003 03:02 PM
