Engine Serial Number location and Coolant?
I see a lot about using ELC coolant depending on the engine serial number, where can I find this. I have a F350 2000. I suspect the local Napa store carries a good ELC, with the upper radiator hose that goes around belt, etc... I read that the sn# determines which ELC I can use if at all.
Does it seem like a DIY process, then having to dispose of it versus a mechanic doing this?
Thanks again for the help, I love this forum and all these inexpensive projects for peace of mind. Although I am too nervous to do the .50 cent mod because I don't know what to remove to get to valve covers. Or the gas tank mods because I am too nervous (self imposed because you guys have always helped here).
I read a good article on reverse lights but the pictures didn't show up, does anyone have the actual wiring diagram? I like the idea of how bearhunter had it wired up.
https://www.ford-trucks.com/forums/5...with-pics.html
Early '99 and older need to stick with a traditional "green" coolant.
You have a MY 2000 rig so you're fine.
Stewart
Mostly it's the injector cups. International, who made the engine, found some compatibility issues with the older injector cup material, sensors, front cover, seals, gaskets, o-rings, and probably some other stuff when using coolants that contained organic acid technology (OAT). Coolants like ELC's (usually Red) and G-05 (usually Gold) will have these OAT's. Conventional coolants (usually Green) will not.
So International revised those components on all 2/2/99-up build engines (SN 940614-up), and began recommending and factory filling with HD ELC coolants mid-year 2000. Never looked back.
You could use HD ELC's in the older engines, but you run the risk of having to replace the cups and maybe some other stuff. I always try to recommend conventional coolant meeting ASTM D4985 with SCA or a pre-charged conventional coolant meeting ASTM D6210 for those. But it's your call, and some owners use the ELC in their older engine successfully. For the 2/2/99-up builds I would highly recommend upgrading to HD ELC.
BTW, if you need to check the build date of your engine, you can find it on the valve-cover tag (driver's side), or stamped on a machined surface on the underside of the engine, behind the oil filter and just ahead of the bell-housing cover. You may need to wire brush/clean it to read it.
Stewart
I thought I purchased this from you or something.I noticed the coolant looks green, but is very dirty "ish".
I noticed that info, thank you, what always confuses me is late 99, where is the cutoff and its a 2000 with a late 99 motor, etc.... but I get your point, thank you.
You have a model year 2000, no where close to an early '99 MY rig so you're good to go.
Stewart
You can easily do the fifty-cent mod. Pulling the valve covers is no big deal. Just remove the IC pipes and you will see the path.
If I were you, I would not worry about ELC. It is good for long term, but can be expensive and unless you run a ton of miles, may be a waste. The Gold coolant works pretty well and also lasts 50-100k. Just an option for you.
