My 96 351w rebuild
My 96 351w rebuild
Hey guys I think I’ve finally figured out my engine build. I just need some more advice and opinions.
I plan on getting my block back from the machine shop on Friday. The block has been bored .30 over making it a 357. I finally got myself some gt40 heads. I am thinking of milling these heads .30 to bring my compression up. Any opinions on this? I plan on running 1.7rr’s with these and I highly doubt there would be any clearance problems but opinions are welcome.
I hope to get these roller rockers
Crane Energizer Pedestal Mount Roller Rocker Arms 44746-16 - SummitRacing.com
Do you guys suggest going with different valve springs?
I plan on using the stock intake, injectors, etc. With this combo and pace setter long tubes I’m hoping to get 400+ torque. If I need anything else to achieve this number help me out. Thanks
Since you're rebuilding the bottom end anyway don't mill the heads to raise compression instead use flattop pistons with valve eyebrows, that provides clearance for bigger valves and a high lift/long duration cam should you decide to add one in the future, and eliminates the real possibility for port misallignment between the heads and intake manifold. Otherwise eveything else sound good.
79F350400m
18
Mar 30, 2018 01:00 AM
fireman660r
19
Feb 13, 2009 02:16 PM
gearhead351
Aug 16, 2007 10:33 PM
captainkirk
25
Sep 19, 2005 11:31 PM
Lifted78
15
Nov 23, 2003 10:21 AM
