No cranky cranky
No cranky cranky
2000 f350 7.3 auto
Gentlemen,
I've done the search, and although there are very similar symptoms described there, I still feel I have to put this out to ponder.
Like it says, engine won't crank. I used a screwdriver as a jumper between the two poles on the starter switch/relay that is mounted on the passenger side fender, and sure enough it cranked right away and started. Soooooo, my conclusion was I needed a new starter relay. Installed a new one, go to start it, and........you guessed it no crank. There was however a buzzing sound coming from a component which is mounted very close to the starter relay. I have no idea what it is however. Anyway, I did the screwdriver jump thing again, and it started right up again, and the buzzing sound from the "component" went away.
So, did I get a bad switch/relay, or did I hook it up incorrectly, or is something else wrong.
I took all the wires off the original relay one by one and mounted them onto the new relay accordingly, so I'm pretty sure i got the wires right.
Gentlemen,
Tempted to agree with Christof here, sounds like the low current side of the relay isn't getting signal, which would lead back to an ignition switch. Not sure if there's any other electronics involved in the starter setup, but I don't believe so. Could apply 12V to the low current side to eliminate the relay for sure though.
I truly don't know if our trucks are set up this way but, If i remember right. There is a shaft from the ignition lock to a electric box at the bottom of the steering column that operates all the power from the key.
some times it will move so when you turn the key, The rod will push the whole box because the screws have come lose, instead of pushing the inner rocker over to the right position to make the connection to start..
X2
Did you check for a current from the small connector? Use a volt meter to check if power is going through the small connector. Have someone turn the key to 'start' as you are using a volt meter to check this for current. Your old starter relay may have been fine.
Also there is a relay on the starter. I was having the 'clicking' problem..... changed fender relay, did not help... turned out to be the small wire going to the relay on the starter was corroded up with a lot of green corrosion. cleaned it up with electrical spray cleaner and everything is good with no starting problems.
.....how weird is this? I jump into my truck this morning and it fires right up!
No tools required!
I know I'm not out of the woods, 'cuz obviously something is not right.
Maybe it's a question of a loose connection as someone suggested, maybe my alarm system is screwing with me. I'll still do the check list you all suggested and get back to you all.
BTW I drove the truck around all day today without any issues.....weird.
No tools required!
No tools required!
No tools required!
I had a similar problem. The shift lever was sloppy on mine. I'd turn the key and nothing, then bump the lever and it would fire up as usual. My dad's F-150 had the same trouble. I just tightened the bolts as noted above and the problem was solved! I found the solution by searching this forum.
