battery light
Old Nov 13, 2012 | 11:48 AM
Polkster's Avatar
Polkster
battery light
Put 2 new batteries in. Shop said alternator ok. Why isbattery light on. Stays on constant. Used to blink.
Old Nov 13, 2012 | 11:58 AM
Cmedic's Avatar
Cmedic
Make sure all connections are clean and tight including the ground leads on motor. Also check connections on the rear of alternator. This is where I would start. I'm sure some one with more experience will chime in here to help.
Old Nov 13, 2012 | 12:08 PM
howellt39's Avatar
howellt39
Pretty biased since I've had two alternators go in the last 23 months, but I'd swap a known good alternator into the truck just to be sure that's not the problem. The regulators on the back can be problematic.
X2 on all connections clean and tight. All fuses are good, correct? Battery clamps not cracked? Easy stuff first...
Old Nov 16, 2012 | 07:22 PM
maverick5.0's Avatar
maverick5.0
alternator, have it checked again by a different shop and if you can swing it, buy it with lifetime warranty... 3 alternators on my 7.3 dually replaced so far... load test the batteries,had to change my new(chain store) batteries two times in 10 months... check the two wire plug for damage/internal short... check the 10 guage wire's lug connector at the back of the alternator for rust or if is burnt.... good luck
Shutech
Apr 21, 2015 09:31 PM
fancyvern
Nov 2, 2012 03:34 PM
jakesfj40
Nov 6, 2011 08:49 PM
orthogod1
Jan 5, 2008 04:46 PM
