05 Aviator subwoofer access
Old Nov 13, 2012 | 08:48 AM
rwkinch's Avatar
rwkinch
How do I get to the subwoofer in this vehicle. It is in the side panel of the rear cargo area of the vehicle..Do I need special tools? Thanks Roger
Old Dec 7, 2012 | 07:14 AM
rwkinch's Avatar
rwkinch
cananyone steer me to previous a previous article.?.i cant seem to find anything on this subject.
Old Dec 7, 2012 | 12:12 PM
shorod's Avatar
shorod
I'm not sure if there's a previous article. A couple months ago I removed the subwoofer from my Aviator to inspect it, it wasn't a quick task. The third row seat has to come out, the passenger rear seat needs to be folded forward, lower passenger rear seat belt bolt comes out, then trim to allow access to the rear interior trim panel gets removed to allow the large interior trim to come out.
Once you get the trim piece out of the way (which includes the subwoofer grill) you can unbolt the subwoofer assembly (driver, amp, and plastic enclosure). There is a screw from the backside of the enclosure that attaches to the subwoofer motor structure so you need to remove the enclosure assembly to remove the driver.
[edit] Here's a photo I took while starting to put everything back together. FWIW, I took mine apart to confirm the amp was working. The bass in my Aviator is not as impressive as what it was in my 2004 Mountaineer. The amp is working fine, it must just be due to all the added sound deadening material in the Aviator?
-Rod
Old Dec 7, 2012 | 01:49 PM
rwkinch's Avatar
rwkinch
Oh my freaking Lord!!! Haaaaaaaaaaaaaa.. Now that looks like a project!!.. Maybe you can answer this.. My daughter says it sounds like her speaker is blown. Is the speaker replaceable with another speaker...or is this all one unit? P.S. thank you so much for this info!!.. wish it wasnt winter...this looks like a nice summer job!!
Old Dec 8, 2012 | 11:52 AM
shorod's Avatar
shorod
The subwoofer is replaceable, but it is a dual voice coil unit (8" if I remember correctly) but rather shallow. There have been other posts about people sourcing aftermarket units (I think JL Audio was a popular choice) but I don't recall the specifics. You'd want to make sure to plug the hole in the rear if you were to go with an aftermarket driver.
You might want to experience what she's referring to first hand before tearing in to this project. Maybe the sound is just due to a rattle somewhere.
-Rod
Old Dec 8, 2012 | 01:01 PM
rwkinch's Avatar
rwkinch
Rod..thank you so much for this information!!!!
naiku
Sep 13, 2016 09:22 PM
guitar4him
28
Aug 6, 2013 08:22 AM
pitmanr2003
Apr 14, 2009 01:31 PM
18fan
Jan 29, 2004 05:34 PM
AKASarin
Feb 25, 2003 07:19 AM
