Oil Pump Shaft Question
Old Nov 12, 2012 | 08:58 PM
rebel33382's Avatar
rebel33382
I dropped the oil pan and oil pump on my 66 352, the oil pump shaft came out while pan was still in crossmember, and I cannot figure out if the round keeper on shaft goes towards the pump side or block side? Anyone remember off hand
Thanks!
P.S. Had a half of hand full of coke/carbon in bottom of the oil pan.
Old Nov 12, 2012 | 09:55 PM
birdhaus's Avatar
birdhaus
I believe the round keeper is supposed to keep the shaft from dropping from the dizzy/ top.... (mine dropped into the dang pan...)
I dropped my pan and found an extra shaft lying in the bottom...
I took took the entire thing out, cleaned it, tested the oil pump,
and checked the box that says "learn the hard way"
Old Nov 13, 2012 | 05:00 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Up-towards the distributor. Keeper only sold with the shaft, not available by itself.
Old Nov 14, 2012 | 08:40 PM
rebel33382's Avatar
rebel33382
just put oil pump and shaft back in, had wife bump the starter and the shaft did not turn, should it? took a small ignition wrench and the shaft turned freely. Any experience out there?
Old Nov 14, 2012 | 11:02 PM
birdhaus's Avatar
birdhaus
the shaft should turn.. the dizzy should crank it.
Had the same experience. is the keeper still in? Its not necessary, but helps the shaft from not fallin into the pan. that being said, seat the shaft into the dizzy.
when you crank the engine, keep your ears tuned for low oil pressure.
turn off immediately if that shaft isn't spinning the pump.
anyone have a trick to keep that shaft seated? Smarted guys always have a way to work around these situations.
Old Nov 15, 2012 | 06:43 AM
f5fordgirl's Avatar
f5fordgirl
The little clip goes up, its job is to keep the shaft from pulling out of the oil pump if you remove the distributor.
kansas storm 350
Apr 25, 2017 12:50 PM
bsaastad
15
Apr 18, 2016 07:38 AM
Swatter
Dec 26, 2012 05:59 AM
53OlderThanMe
Nov 14, 2008 07:43 PM
AZ 56 & 03
152
Feb 15, 2007 09:19 AM
